Oil Pressure Sender on Engine Head
Old Jul 5, 2014 | 04:02 PM
selp's Avatar
I just installed an EF4 on my Evolution IX, the turbo install kit uses an oil line that attaches to the oil filter housing, which is where I had my oil pressure sender installed. Now, I have nowhere to install the pressure sender, I was wondering if I could use the old oil turbo line plug on the engine head?
Maybe using a line like this? http://www.amsperformance.com/cart/A...Unit-Line.html
I heard plenty of bad reviews using a sandwich plate on the oil filter housing, so I would like to stay away from that. Anyone has any good ideas?
Thanks
Old Jul 5, 2014 | 04:11 PM
TurboTravis's Avatar
There is more than 1 port on the oil filter housing-use one for the turbo and one for the pressure sensor.
Old Jul 5, 2014 | 04:13 PM
selp's Avatar
I forgot to mention that I have a temperature gauge on the other port.
Old Jul 5, 2014 | 04:21 PM
killerpenguin21's Avatar
put temperature in the oil pan where it should be. taking a pressure reading at the head is not accurate.
Old Jul 5, 2014 | 04:37 PM
selp's Avatar
Are both plugs on the oil filter housing the same size?
I could get the ams oil pressure line, with a T adapter for the oil pressure and oil temperature.
Could that work?
trinydex
141
May 18, 2018 09:34 AM
sonicnofadz
Sep 14, 2015 07:52 PM
fjm9898
Dec 24, 2013 06:13 PM
Pale Horse
Jul 26, 2013 09:47 PM
the1tonton
Jan 30, 2013 06:56 AM
