radiator trouble
Old Dec 7, 2011 | 11:50 AM
awdordie's Avatar
radiator trouble
thanks in advance for any input.
my question is can a radiator just crack or start to leak without any changes or impact to the radiator?
i ask because last night after going to the store i was sitting on my phone with the cart idling and started noticing smoke from under the hood. at first i thought it was just from the rain. well i pulled off and at the next light it was doing the same. temp gauge never rose above what it normally does.
i couldnt do much searching since it was dark but today when i looked everything looked normal that is until i started the car. before doing so i checked all hoses by squeezing them to see if coolant seeped out. once started and warmed up with the heater on full coolant started to collect along the top edge, closest to the motor, and only on the serpentine belt side up to the filler neck, around the side of the radiator on the passenger side and some on the front top edge.
if i havent messed with the top hose could the filler neck crack on its own? could it just be old and be seeping past where the plastic meets the metal and is held together by the metal finger tabs? im assuming the radiator is leaking and since it drips down onto the lower ic pipe right in front of my dump pipe that when driving its causinfg it to blow onto the dump and my exhaust causing a bit of smoking when i stop.
Old Dec 7, 2011 | 12:03 PM
SilverShadow03's Avatar
Yes, it can happen.
I had a leak at the top of the radiator where the plastic top mates up with the aluminum portion of the radiator on my 03 Evo 8. I ended up replacing the entire radiator with an oem style replacement radiator. Works fine now and has been leak proof for over 40K miles.
Old Dec 7, 2011 | 12:18 PM
chu's Avatar
chu
Yeah, it also happened to me, right at the filler neck. Just barely noticeable, but I can happen. I used the opportunity to get a Mishimoto aluminum one to replaced with.
Old Dec 7, 2011 | 12:35 PM
Gsst98's Avatar
I had the exact same problem radiator looked fine but was pooling at the top. You can get a decent Aluminum radiator for $250ish, I did the same as chu. It looks much better than stock and fairly easy to install.
Old Dec 7, 2011 | 01:10 PM
awdordie's Avatar
Anyone know if your suppose to pressure test it with the coolant drained? I rented one and im trying it now with soapy water but all im getting is coolant puddling just like with the car started and I can't seem to find where its coming from. It does seem to be starting right under the filler neck like someone mentioned.
When I pressure it to around 14psi I get quite a steady stream dripping. Should I avoid driving the car until I get a new radiator or can I just top it off and make sure I have antifreeze and water with me? I kinda have to work this weekend and have no other way to work and I doubt I can get a radiator before then even the parts place said its special order.
Old Dec 7, 2011 | 01:11 PM
mdsevo06's Avatar
Other the the crimp over the plastic end tank, it's uses a adhesive bond to hold it to the aluminum core. I replaced mine with the Mishimoto for about $225 shipped.
Old Dec 7, 2011 | 04:41 PM
barneyb's Avatar
You can pressure test it either way. Most people do it with coolant. Coolant leaking is easier to see than air.
As for driving it, I would not. Get it hot and blow the head gasket and you will wish you had rented a car.
Old Dec 7, 2011 | 09:06 PM
Boostevo58's Avatar
I can see mines is starting to crack there also. Its just wear and tear.
Old Dec 7, 2011 | 09:51 PM
3K's Avatar
3K
Same thing happened to me. It's from the hose pulling on the radiator when the engine tilts back under hard acceleration. When the radiator gets old the plastic gets brittle.
Old Dec 7, 2011 | 10:14 PM
whitedsm97's Avatar
Mine did the same thing also which sprayed coolant on the side of my valve cover. I went and ordered a two row aluminum off of ebay for 147 shipped. Been good ever since.
Old Dec 8, 2011 | 08:56 AM
ca18hatch24's Avatar
Yeah, the plastic gets brittle and can crack over time due to the heat cycling. I agree, don't drive that thing if it can be avoided.
Old Dec 8, 2011 | 11:55 AM
awdordie's Avatar
Well Im getting my girl to take me to and from work this coming weekend and ordered a koyo aluminum radiator to avoid future problems. Its annoying being forced into modifying the evo when im tight on money, but im not one of those who just buy oem. If it breaks fix it with something better is the way I see it.
kwpilot
Feb 20, 2023 09:29 PM
DSSA
Evo X How Tos / Installations
19
Sep 7, 2017 02:57 AM
MisUnderStood
Jun 23, 2016 04:02 AM
BrandonIX
15
Jun 12, 2016 08:17 PM
awdordie
28
Feb 20, 2016 01:09 PM
