Removing valve cover
Old Dec 7, 2011 | 04:22 PM
Jush's Avatar
Wink Removing valve cover
Hey all
:h elpme:
Has anybody got/know of a guide for taking off the valve cover for a Evo 6?
I want to repaint it.
I've got a guide for a Evolution X as that was all I could find.
Preferably with pictures :P
Some questions you may be able to answer:
- Do I need to drain all of/some of/none of the oil before taking off the valve cover?
- What is the best way to cover the engine while the valve cover is off (I was thinking gladwrap and duct tape)
- I understand that the engine is very strong, but is there anything I will need to take extra care of?
Any information is greatly appreciated
Old Dec 7, 2011 | 04:45 PM
WHTEVO's Avatar
Wow. Well, it is pretty straight forward. Remove anything in the way (vacuumm hoses, coils, etc), remove the bolts, and off it comes. Can cover the exposed engine with plastic bag of some sort. No, you don't need to drain the fluids. Good luck.
Aaron
Old Dec 7, 2011 | 04:50 PM
wizzo 8's Avatar
When you go back together be sure not to overtighten the valve cover bolts. Only needs like 10Nm.
Old Dec 7, 2011 | 04:56 PM
Jush's Avatar
Aaron
None of these things are sensitive peices? all pretty straight forward?
Old Dec 7, 2011 | 05:23 PM
llDemonll's Avatar
Yep - nothing up there that you can hurt unless you really try hard or really mess up. just put the cover on the way way it came off, torque down the bolts to spec, bolt everything else back up and you're good to go. I'd get a new valve cover gasket though
Old Dec 7, 2011 | 07:42 PM
GGevo921's Avatar
+1 on gasket and make sure to torque down to spec or you can crack the cover, put pictures up of it when your done painting it!
Old Dec 7, 2011 | 07:47 PM
Jush's Avatar
Why would I need a new valve cover?
Old Dec 7, 2011 | 07:49 PM
Jush's Avatar
Won't be anything special, just a nice matte black finish. I may hand do the words back ok.
Old Dec 7, 2011 | 07:50 PM
GGevo921's Avatar
he said a new valve cover GASKET, not a new valve cover. Its always a good idea to replace the gaskets. im removing mine to do cams and springs and retainers and and im doing all new valve cover gaskets, cam seals, spark plug gaskets etc.
Old Dec 7, 2011 | 07:51 PM
GGevo921's Avatar
Flat black is sick, should put up a picture anyway!
Old Dec 7, 2011 | 09:58 PM
Jush's Avatar
I see, completly miss read it. Yeah should look good. Will definitly post a picture up.
Old Dec 11, 2011 | 02:30 PM
Jush's Avatar
Almost finished with the valve cover. I've been taking pictures as i've been going and will make 'build thread' about it. They weren't kidding about the 8 hours prep and paint!
I'm thinking gold for the words. What do you all think?
Old Dec 11, 2011 | 02:57 PM
volkevo9's Avatar
pic
Post pics when done. Get a new gasket.
Old Dec 11, 2011 | 03:12 PM
mmmmbst's Avatar
Veteran: Air Force
If you're feeling crazy, make a How-to thread so it will help others in your situation. Positive contributions keep this forum alive. Its an easy process but will get your foot in the door to the evo community.
Old Dec 11, 2011 | 03:25 PM
Jush's Avatar
I could do that. It was a very simple task really, most difficult part was sanding.. for hours on end.
Evo_Goodness
Dec 19, 2020 02:39 PM
chopzilla
Jul 7, 2019 10:09 PM
GhostEvo^X
Jul 3, 2017 11:25 AM
RyanD3
Mar 8, 2016 02:37 PM
Evo8
May 15, 2006 05:57 PM
