Prosport oil pressure sensor install help
Old Dec 24, 2011 | 04:30 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by TurboTravis
MAPP/Propane torch from Sears or most any hardware store will run you like 30 bucks
Old Dec 24, 2011 | 04:41 PM
aeroweenie's Avatar
I had no problem removing the bungs, used one for oil pressure, the other for oil temperature - no torch required. Make sure you have the correct size allen wrench.
The only way I know to get it out if the allen head is stripped is to drill it and reverse tap it, or use an ez-out. Not something I would do except as a last resort since you may get metal shavings in the oil system.
Old Dec 24, 2011 | 05:05 PM
TurboTravis's Avatar
I also had zero problems just using the correct size tool, some PB Blaster, and a little common sense. The only locktite that requires heat to be removed is the red.
Old Dec 24, 2011 | 05:06 PM
And, as long as the access was there, an impact gun with short bursts would be the preferred way to do this.
Old Dec 24, 2011 | 07:58 PM
Evoryder's Avatar
I got my propane torch from homedepot. Like $20 - $30
Comes in handy In most applications. Especially older bolts.
Old Dec 24, 2011 | 08:39 PM
PatricksEvilEvo's Avatar
Just drill and tap it. Go buy a kit they come in handy
Old Dec 24, 2011 | 08:58 PM
ryancb's Avatar
Id just order the same thing from houseofhose.com cost me $15 shipped for a 3 ft hose that has it nice and safe.
Old Dec 25, 2011 | 10:12 AM
Nofear23's Avatar
Thanks guys. Thinking I'll just go with the AMS line and hope it fits on the other bung and doesn't hit anything. Should be ok I hope.
Old Jan 23, 2012 | 09:51 PM
McDougal's Avatar
What is the benefit of doing this compared to getting one of the sandwich adaptors?
Could someone post a picture of the bungs? Are there near where the oil filter screws on?
honda-guy
28
Jan 30, 2021 08:48 PM
Howulikemyevo
Mar 29, 2016 08:58 PM
Howulikemyevo
Jan 8, 2015 09:23 AM
erald01
Jun 11, 2011 01:15 AM
DanInPA
Aug 17, 2006 05:06 AM
