Vishnu performance?
Old Dec 27, 2011 | 09:16 PM
Guitarplyr's Avatar
Vishnu performance?
SO I was tinkering in my evo today, since its parked because of a bad tc. The blower motor is making noises so I pulled off the glovebox and see a vishnu perfomance xede. I assumed it was a piggyback and started researching. Is this company even doing anything anymore and how the hell do I use it etc? I am at a loss for knowing whats going on here and if this thing is even supported. Thanks for helping a noob!
Old Dec 27, 2011 | 09:28 PM
Murf's Avatar
Remove, and use as a paper weight. Was used a lot before ecuflash came about.
Old Dec 27, 2011 | 09:30 PM
Guitarplyr's Avatar
I see. Yeah I'm getting the impression it's a bit.....outdated
Old Dec 27, 2011 | 10:45 PM
Montu's Avatar
lol yea its pre ecu flash
get a good tune and toss it
are you all stock? why didn't you notice this a long time ago?
Old Dec 28, 2011 | 08:56 AM
Guitarplyr's Avatar
Only had the car since August and am still figuring out what all is done to it lol. I'll get it out ASAP. Im def not stock. Uicp and Licp full tbe hks 264/264 cams and intake. At least that's what I've found so far.
Old Dec 28, 2011 | 09:07 AM
Murf's Avatar
You don't need to remove ASAP. Wait until t case is back in then find a tuner to remove and retune. Betting it's set for what's in your car now so just hold on till then.
I'm thinking the closest would be English racing
Old Dec 28, 2011 | 09:54 AM
Montu's Avatar
yea get a tune using ecu flash ...but its better to have that box then to run your car untuned.
Old Dec 28, 2011 | 10:15 AM
Teal2nnr's Avatar
^^^ Thats what i was going to say.....wait until you can get it tuned.
Old Dec 28, 2011 | 11:06 AM
Guitarplyr's Avatar
Oh no no I know that. Lol.
Old Dec 28, 2011 | 09:45 PM
Guitarplyr's Avatar
Most shops tune ecu flash then? I want something user friendly that I can eventually use as I want to learn to tune. Something with user loadable maps and map switching that type of thing. Also wouldnt it be better to use a standalone ecu? Doesn't the stock one have a finite number of flashes and then it's a rock?
Old Dec 28, 2011 | 09:50 PM
TurboTravis's Avatar
Zero need for a standalone in your case. No # of flashes, you could have someone flash you all day. Wait, not sure if that sounds right..
Anyway, ECUFlash is free. What you'd need to buy is ECUScan, and a cable.
www.evoscan.com
Old Dec 29, 2011 | 05:24 PM
Guitarplyr's Avatar
www.evoscan.com
gotcha. How much does tuning cost generally? Or could I just download a map for that program with my mods in mind that someone else has?
Old Dec 29, 2011 | 05:29 PM
Montu's Avatar
no get a custom map..every car is different a tune from my place of preference cost 200 an hour...with first time tunes usually being close to 2 hours and touch ups being 1 hour or less.
similar map's from other people with the same mods should only serve as base maps or emergency maps.
Old Dec 29, 2011 | 05:32 PM
Murf's Avatar
Ecuflash and evo scan, then start reading reading reading the ecuflash section.
Old Dec 29, 2011 | 08:20 PM
Guitarplyr's Avatar
sounds like I have alot of learning to do lol thanks for the tips
