About to Pull my hair out! fuel problem!
Old Dec 31, 2011 | 03:01 AM
3K's Avatar
3K
Is your fpr adjustable? if so did you adjust it?
Old Dec 31, 2011 | 06:55 AM
wizzo 8's Avatar
Its an Aeromotive so yes its adjustable. He shouldn't have to adjust it after the new fuel pump though.
Old Dec 31, 2011 | 07:54 AM
drb's Avatar
drb
Loosen the adjustment lock nut on the top of the FPR and turn the (allen head) adjusting screw in (clockwise) a few turns. If the reading on the pressure guage does not go up there is a problem with the gauge or with the FPR.
Old Dec 31, 2011 | 09:39 AM
5LEEPERISAH23I's Avatar
it did it sits at 5 psi
Old Dec 31, 2011 | 10:33 AM
heavens turbo's Avatar
5 psi is virtually no fuel pressure, so your car would not be running. check at the rail for diag.
Old Jan 2, 2012 | 09:41 AM
FOUND PROBLEM kind of. Its fuel housing something is not seating correctly. Im done playing games with it and cant figure it out. Im going to just take the hit n buy a double pumper. Found the problem bec i have my friend bring his Evo over n dropped in his housing n pump problem fixed.
Old Jan 2, 2012 | 05:09 PM
coryd's Avatar
yes, but that doesn't help you really. when u put in his pump what did the fuel pressure read? afr? Did you put ur 255 or 400 in his housing then put it in your car to check your pumps? It just doesnt make sense that your only getting 5 psi regardless of how you set you FPR.
Old Jan 3, 2012 | 03:12 PM
i put the 255 in his. i was getting 35psi or something put it fixed the problem tho
Abacus
Sep 18, 2025 05:44 AM
USCGSAM
Aug 1, 2019 06:37 AM
Dynotech Tuning
39
Dec 3, 2016 11:04 AM
vmrevo9
Sep 5, 2012 05:58 PM
