Pulling to the left under acceleration
Old Jan 23, 2012 | 10:49 AM
  #31
dastallion951's Avatar
well a simple way op to rule out tire pull, swap your front tires, go for a drive and see if the pull when and not accelerating has gone to the opposite side, if so then swap tires front to back, see if it gets rid of it. Im guessing youve probably driven on them long enough youve probably worn the front tires down to almost secondary rubber. Which means the wear pattern wont change, and the car will only pull different if you swap the tires or replace them. Good luck.
Old Jan 23, 2012 | 10:52 AM
  #32
MRadjahoe's Avatar
Originally Posted by Chef-j
How many milies tho? have you ask previous owner see when he/she did alignment?
Idk, i wouldn't go worry too much yet untill you go check the alignment. Idk that's just me.
Unfortunately bought it from Warner Motors in PA I don't know the previous owner.
Old Jan 23, 2012 | 10:57 AM
  #33
MRadjahoe's Avatar
Swapped tires last week. No change... still pulls to the left but not as much. I am installing new suspension on the car, I will see if that changes anything. If not I will have my shop look at it.
kobi2002
Apr 19, 2017 02:57 PM
Thahomeboyb
Lancer Troubleshooting
Apr 3, 2014 01:48 PM
FOOKhonda
11
Feb 20, 2014 07:44 AM
Sanny632
15
Dec 7, 2013 05:17 PM
ilikeppie
11
Jul 6, 2012 10:58 AM
