Thrust bearing crank pulley side gone?
Old Jan 9, 2012 | 08:43 PM
quiquepr69's Avatar
Angry Thrust bearing crank pulley side gone?
Hello everyone!, well to make it short here is the issue, I (me)install an ACT clutch kit with ACT flywheel, last year. Today I notice a metal to metal noise coming from the oil pump, so when I took the timing cover out and turn the engine with the ratchet, the metal plate for the crank sensor was hitting the sensor. This was weird so I grab the side of the crank and pull it back and forward and there was mayor end-play. I remove the oil pan, oil pump, and lower main bearings cap set, well the thrust bearing it was as thin as a paper in the timing belt side (not clutch) and the crankshaft have a groove big enough to know that is done, zip, to the trash. Any input on this matter or if someone have this problem before? thanks in advance.
Old Jan 10, 2012 | 06:15 AM
quiquepr69's Avatar
Unhappy Thrust bearing
Really no one have this problem, come on !
Popeusmc
Jul 23, 2016 10:29 PM
BeastYamin
For Sale - Cars For Sale
19
Jun 16, 2016 12:22 PM
turboedv6
28
May 13, 2016 04:31 PM
A4RON
Apr 26, 2016 02:02 AM
O0oDC
26
Sep 3, 2015 05:46 PM
