Idle problem.
Old Jan 18, 2012 | 07:23 AM
Kodiak's Avatar
Idle problem.
I was driving into work this morning and just as I was turning into the parking lot the car stalled. Now it will not idle without stalling, I can start it and as long as I feed it a little gas it runs. I checked the IC piping and it seems fine. Anyone have any suggestions?
Old Jan 18, 2012 | 07:38 AM
Tekniq's Avatar
Do you have cams? If it just started out the blue today, a hose probably popped off.
Old Jan 18, 2012 | 08:00 AM
Kodiak's Avatar
Checked all the IC piping seems ok. I stated it up again and it Idled for about a minute then when I revved it it died again.
Stock cams BTW.
Old Jan 18, 2012 | 07:10 PM
Tekniq's Avatar
Check the hose under the throttle body.
Old Jan 19, 2012 | 02:45 PM
Hendrixmx's Avatar
bad iac
Old Jan 19, 2012 | 03:54 PM
chrisw's Avatar
Originally Posted by Hendrixmx
bad iac
yup...
Old Jan 19, 2012 | 05:11 PM
vmrevo9's Avatar
Veteran: Air Force
how can you tell if its a bad IAC valve?
Old Jan 19, 2012 | 06:57 PM
barneyb's Avatar
Well, that is the other possibility. In the OP's case It is either a vacuum leak or a bad IAC.
Old Jan 19, 2012 | 11:32 PM
BlackEight's Avatar
My brothers 03 evo had the same issue couple years ago. His IAC valve started dying and acted similar to what you're experiencing. Not too sure how to test it.
Old Jan 20, 2012 | 12:26 AM
EVO8emUp's Avatar
From the manual:
Measure the resistance between idle air control motor
connector terminal No. 2 and either terminal No. 1 or
terminal No. 3.
Standard value: 28 − 33 ohms [at 20°C (68°F)]
(3) Measure the resistance between idle air control motor
connector terminal No. 5 and either terminal No. 4 or
terminal No. 6.
Q: Is the measured resistance between 28 and 33 ohms [at
20°C (68°F)]
Looking at the connector with the clip facing up the pins are as follows:
1 2 3
4 5 6
Old Jan 23, 2012 | 05:44 PM
vmrevo9's Avatar
Veteran: Air Force
so what is it supposed to do mechanically? if the resistance checks fine how do we know if its mechanically ok?
Old Jan 23, 2012 | 05:48 PM
Revo15's Avatar
Unplug battery to reset if problem still exists its your IAC!
Old Jan 23, 2012 | 05:50 PM
Revo15's Avatar
Also check plugs...fuel..could be fuel pump!
Old Jan 23, 2012 | 06:00 PM
vmrevo9's Avatar
Veteran: Air Force
well i was able to adjust the cars idle with the BISS screw and unpluging the battery help me set up everything. i thought it was good to go until i drove the car. once i would come to a stop the car would stumble and want to die. eventually it would die coming to a stop.
so am i looking at a bad IAC? i was told to unplug the IAC and the car should go up to ~2300rpm. the car seems to not care if its plugged in or not.
Old Jan 24, 2012 | 12:18 AM
EVO8emUp's Avatar
Did you disable the ISC while adjusting the BISS?
