What type of oil for my 04 Evolution VIII Rs??
Old Jan 22, 2012 | 06:27 AM
evox4b11turbo's Avatar
I been looking all over the place to find what type of oil i need to use for my evo.. Summer is comming up in Arizona and the temp gets up to about 115 degrees and im wondering what type of oil is OEM for my car...
Any help???
Thank you!!
Old Jan 22, 2012 | 06:39 AM
grillpt's Avatar
Mobil1 is OE, says so right on the oil cap.
I recommend M1 High Mileage, 10w-40 for summer months. 10w-30 is OE weight.
Old Jan 22, 2012 | 06:47 AM
sparky's Avatar
Wow! 115 degrees F. ambient air temperature is truly cooking. I would advise fitting your car with an oil temp gauge so that you will be able to monitor your oil operating temps. Cars that experience higher oil operating temps require a higher viscosity oil. As oil operating temps rise, oil gets thinner.
Old Jan 22, 2012 | 08:04 AM
sparky's Avatar
If I lived in AZ I would upgrade the factory oil cooler to a larger and more efficient aftermarket unit, such as, the SETRAB P/N 50-625-7612.
Old Jan 22, 2012 | 08:06 AM
Evo3573's Avatar
Brad Penn 10w40
Old Jan 22, 2012 | 07:26 PM
sparky's Avatar
If I lived where you do, I would run a motor oil that is better than Mobil1. Myself I like Motul 300v. Either their 10W-40, or maybe even the 15W-50. The stuff costs about $15/Qt. online. Sure, there are other good oils out there.
Also, you might want to look into the Tomei ThermoKiller.
Old Jan 23, 2012 | 10:36 AM
Fatskunk's Avatar
I have used nothing but AMSOIL in numerous cars over the years with nothing but positive results.
Old Jan 23, 2012 | 11:03 AM
donmeca2020's Avatar
i would stick with mobil 1
Old Jan 23, 2012 | 11:08 PM
Yeah 115 degrees F. is a normal summer day in Arizona so an upgraded oil cooling system is for sure something im gonna look into getting... and as far as the oil goes i might just use a thicker oil like 10w40 for the summer.. And im looking into different types of oil and what would be better..
And an oil temp gauge is something that i am getting as well.. Im probably just park the car as much as i can for the summer...
Old Jan 23, 2012 | 11:12 PM
prowakeskater's Avatar
synthetic shell Rotella T 5w40
cangri1788
Lancer Tranny/Drivetrain Tech
Apr 21, 2017 11:33 PM
Boostfiend
Feb 2, 2014 10:16 AM
ajnasrah20083
54
Nov 21, 2012 02:59 AM
PICASO83
Sep 12, 2011 01:53 PM
rashoodi
110
Feb 22, 2008 05:47 PM
