Gauge/Radio wiring help
Old Feb 5, 2012 | 03:08 PM
Pssst's Avatar
While wiring my Prosport gauges...(which I clearly messed up) I wanted to test the power source so I grounded the gauges... touched the power to the radio clip's power and they worked for as long as I held it, then I tried one more time to confirm and heard a small pop(blown fuse) and the gauges no longer worked... My radio doesnt work now either... I checked my fuse panel and couldnt find a blown fuse there. any suggestions? dash is currently apart...
My owners manual fuse setups look completely different then fuse panels themselves so I dont know which is which...
Any suggestions would be greatly appreciated!
Fixed... the dome light of all thigns in the engine bay fuse panel (in the yellow clip) was the problem. everything works now.
Old Feb 5, 2012 | 04:31 PM
auto228's Avatar
so check every single fuse on your fuse box. And some radio has a in-line fuse by hot wire, check that one too !!!
Old Feb 5, 2012 | 04:38 PM
Pssst's Avatar
Checked each fuse twice, nothing, all were in tact
I tried finding one on the wire but no luck. I took a volt meter to the radio RED going to the clip, its getting power... the orange(illumination?) is not getting any power. Nor is the yellow(constant)
Also my clock doesnt work Nothing but my A/F Gauge and boost gauge work whenever I have the car turned on ACC. no door chime nothing... eeek
Old Feb 5, 2012 | 04:39 PM
thedru13's Avatar
Did you check the fuse panel in the car and the one under the hood?
Old Feb 5, 2012 | 04:44 PM
Pssst's Avatar
Yep checked em both twice
Old Feb 6, 2012 | 06:28 AM
Pssst's Avatar
Update.... my remote doesnt lock/unlock my doors either... Help
dmik
Lancer Troubleshooting
12
Nov 20, 2021 09:12 PM
joonvang
Jul 23, 2017 11:31 PM
SatsuMX
Feb 22, 2016 08:38 AM
llDemonll
Pacific Northwest
11
May 22, 2012 01:35 PM
PG888
13
Oct 7, 2004 11:16 AM
