Antilock and ACD trouble codes help?
Old Feb 7, 2012 | 09:58 AM
VancouverEvo8MR's Avatar
My shop retrieved the codes from my ACD and Antilock and can someone here please translate them?
Evo 8 MR with 5 spd and ACD
Antilock - 11 12 21 22 81 82 83
ACD - 22 25 26
Yes I watched the blinking sequence for a good 10 mins to triple check each light flash was accurate.
thanks in advance
Old Feb 7, 2012 | 02:29 PM
frankmc's Avatar
here are the acd/abs fault codes,
repair your wheel speed sensor's first, then recheck for codes,
the acd ecu will reset itself when faults are fixed
12 power supply open or short circuit
21 fr right wheel speed sensor open or short circuit
22 fr left wheel speed sensor open or short circuit
23 rear right wheel speed sensor open or short circuit
24 rear left wheel speed sensor open or short circuit
25 wrong diam tyre
26 faulty wheel speed sensor
31 steer sensor system(st1,st2,stn)open circuit
32 steer sensor stn short circuit
33 steer sensor stn system
34 steer system st1 st2 short circuit
41 tps open or short circuit
51 longitudinal acc sensor open or short circuit
52 longitudinal acc sensor
56 lateral acc sensor open or short circuit
61 stop lamp switch system open-circuit
65 abs monitor system open or short circuit
71 proportioning valve system open or short circuit
72 directional control valve right open or short circuit
73 directional control valve left open or short circuit
81 ayc relay system open or short circuit
82 electric pump system
83 electric pump system
hachansoo0413
May 13, 2012 08:45 AM
Jingming88
Sep 28, 2011 10:33 PM
CantWaitToBoost
Aug 13, 2011 03:50 PM
section8evo
13
Oct 13, 2009 09:46 PM
rgar
Apr 29, 2009 04:53 PM
