Simple steering wheel question.
Old Feb 8, 2012 | 06:02 AM
5speedwtneed's Avatar
I have a evo IX mr. Before i take the wheel off can anyone tell me if it's splined and I can remove it and install it back in a different orientation?
Old Feb 8, 2012 | 07:28 AM
Bump. Easy question
Old Feb 8, 2012 | 07:35 AM
VAPyro's Avatar
I know the steering wheel on my 8 had splines. I'm not sure if they designed it so it can only be installed in one orientation though, I just took it off and re-installed it in the same orientation.
Old Feb 8, 2012 | 07:42 AM
llDemonll's Avatar
Any particular reason you want to rotate your wheel?
if it's to adjust the car tracking straight....get it done properly with an alignment
Old Feb 8, 2012 | 07:50 AM
Evoardo IX's Avatar
To answer your question, yes, you can take it out and install in a different position. But like demon said, why??
Old Feb 8, 2012 | 07:56 AM
barneyb's Avatar
There's more than eight splines, there are lots of splines. So, no problem changing the orientation of the wheel.
However, this isn't the proper way of straightening a crooked wheel. Straightening the steering wheel is done by adjusting the length of the tie rods, one longer and one shorter until the steering is straight.
I have a wooden homemade gauge in my garage I use for setting toe. Right now I can tell you my car is toed out in front by 1/32 of an inch, not enough to be worth getting out the tools.
Old Feb 8, 2012 | 08:28 AM
Okay calm down lol. My car is in alignment. When I did the front sway bar install. You had to take the splined column apart and my marks got rubbed off >_<. Now my steering wheel is so off center it would be impossible to fix with an alignment. So I have to flip my wheel completely over or else my tie rods would be like 3-4 inches different in length if that's possible lol. So no worries. My car is in alignment. Just got done 2 months ago =D
Old Feb 8, 2012 | 06:58 PM
barneyb's Avatar
Okay, it took awhile but I am calm now. Thanks.
CtSilver03Evo
16
Dec 9, 2025 01:42 AM
antman_21
May 30, 2012 11:57 AM
chad99evo
South Region
Sep 5, 2008 08:56 AM
ManiakMik
Lancer Tranny/Drivetrain Tech
40
Sep 22, 2006 11:30 AM
