whats happening?
Old Feb 12, 2012 | 09:24 PM
brunz44's Avatar
whats happening?
just a quick question for anyone who has imput. My cars been having some type of turbo cut off or boost cut off. From what ive searched the stcok ecu has a cut out point, i bought my car as is so i dont personally know if thats been changed its more in 3rd gear and up, at WOT around 4-4.5k rpms the turbo just shuts off my boost gauge beeps as if it was reaching my peak point but the needle shoots to the bottom of the guage. i can hear the turbo spool as i get on it alittle and then itll cut off. i can still hear my engine going fine its just like the car was a non-turbo car. i dont think its a fuel cut, in no way does the car jerk when it happens, its more like i just go in to civic mode or something. if i release the gas pedal then press it agian my boost just starts to build right back up somtimes it will hold and i can ride the hole gear out with boost somtimes it will just cut off agian around 4k. its kind of a random accurance but i would say it happens more then it dosent happen i had a boost leak on the lower seal of my first injector i pulled the fuel rail and replaced all of them so no more leak i might have a small one somewhere else hopfully not ,checking tomorow. my car throws p0300 to if that could havesomthing to do with the cut off. if someone can just tell me what is happening i can do more searches throughout the site, im just stumped on why its cutting out like it is. thanks alot the mods and specs to the car are below vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv vvvvvvvvvvvvvvv
03 evo 8 26kmiles22psi--93oct----mobile1
3' exhaust
downpipe/02 houseing
arc box/ 3'intake pipe
spoolinup COP
hks 264/264
greddy fmic/ licp
hks uicp/ hks bov recirculated
stock turbo and intake mani and exhaust mani and engine internals
Old Feb 13, 2012 | 06:19 AM
DeFog's Avatar
Not sure if its your problem but once it cuts off once the ecu will remember and continue, just gotta unplug the negative terminal on your battery for 30 seconds or so to let it reset.
Old Feb 13, 2012 | 07:05 AM
evo8426's Avatar
That doesn't do anything but reset your odometer and radio stations
Do a boost leak test and don't continue to floor your car with it running that way. You might damage something
Old Feb 13, 2012 | 07:10 AM
Raptord's Avatar
Sounds like boost cut. If you have an MBC you can lower the boost until it stops happening. If you have a tactrix cable and a laptop you can pull the current map off the car and adjust the load required to activate boost cut.
Old Feb 13, 2012 | 07:15 AM
4RETECH's Avatar
Gap your plugs to ..20- .21. see if that changes anything.
The air got very dense here lately. if you run at .25 you will get spark blow out do to the extra PSI.
Old Feb 13, 2012 | 08:22 AM
brunz44's Avatar
lol trust me man i back off asap i only did the gear without boost once to try and figure out what the hell was going on. im such a baby when somthings going wrong with my car. im checking for leaks once i get to work, since i can pull it in the bay and get out of the cold
Last edited by brunz44; Feb 13, 2012 at 08:25 AM. Reason: forgot important information pretaining to the thread
Old Feb 13, 2012 | 08:33 AM
thedru13's Avatar
The misfire code is probably due to your cams. Mine Does that when it's cold out.
Old Feb 13, 2012 | 08:48 AM
DeFog's Avatar
Just following the directions from hallman, guess they could be wrong? :l
Says even if you turn the boost down without reset to the ecu the
fuel cut will still kick in cause it remembers.
Old Feb 13, 2012 | 09:05 AM
Raptord's Avatar
Boost cut is activated by a load vs rpm threshold in the map. The ecu doesn't "remember" that it previously hit boost cut AFAIK. If it goes over, it cuts boost until you lift off if I'm not mistaken.
evoviiihan
10
Oct 22, 2016 10:00 PM
hung861988
Feb 13, 2015 04:45 AM
CtSilver03Evo
May 5, 2014 09:21 AM
101516
29
May 4, 2014 05:28 PM
5LEEPERISAH23I
20
Feb 23, 2014 02:48 PM
