Need help with exhaust!
Old Feb 16, 2012 | 07:24 PM
evo4life94's Avatar
I recently installed a BR catback w/magnaflow and I noticed it would leak in the mornings. It leaks where it connects to the cat and and the two clamps that came with the exhaust. Why is this happening? Did I not tighten the bolts enough?
Here are some pictures,
Uploaded with ImageShack.us
The next two are the same clamp in the back of the car. This is the only one that makes noise.
Old Feb 16, 2012 | 07:26 PM
4G63kevin's Avatar
Try tightening it a bit more. ;p
Old Feb 16, 2012 | 08:09 PM
evo4life94's Avatar
Ok I will try that and see how it works out
Old Feb 16, 2012 | 08:10 PM
evo4life94's Avatar
And thanks for the quick response
Old Feb 16, 2012 | 08:39 PM
BluEVOIX's Avatar
The slip fits make sure you put them on snug and tighten them down some more. Also double check your have the clamp installed in the correct direction.
The 2 bolt flange leaking make sure the bolts are tightened down. If it still leaks then your exhaust gasket sucks. Try to find a copper gasket or buy a copper sheet generally used for art and cut it out into gasket shapes to use.
This is a nice gasket as well if you dont mind spending close to 20 bucks for it:
http://www.maperformance.com/grimmsp...ck-076001.html
Old Feb 16, 2012 | 08:56 PM
evo4life94's Avatar
Old Feb 16, 2012 | 09:10 PM
evo4life94's Avatar
Sorry for the double post.
I will tighten and check everything tomorrow, thanks for the help!
For the 2 bolt flange I used a vibrant performance gasket that was provided with the exhaust and it seemed flimsy. Maybe that's the cause of the leak at the 2 bolt?
Old Feb 17, 2012 | 04:08 AM
HaVoC187's Avatar
I used a decent gasket and mine would leak aswell. The bolts need to be VERY tight.
Old Feb 17, 2012 | 05:53 AM
elmark44's Avatar
x2 tight it hard! maybe try another gasket?
Old Feb 17, 2012 | 06:06 AM
shrtstuff89's Avatar
If its loose enough to leak, it may be loose enough to work itself apart while drivng. And that would be disastrous.
Impact wrench would likely be handy for the slip on clamps
Old Feb 17, 2012 | 07:45 PM
evo4life94's Avatar
Alright so I did what you guys said and tightened everything down. The second clamp more towards the middle is leak free.
The clamp towards the back of the car doesnt leak water anymore and is noise free, but I can feel a little bit of air coming out even though I tightened the clamp even more. Is this bad or should I buy a new clamp?
The connection at the 2 bolt flange where the gasket is still leaks.
Would putting a second gasket help the problem?
Old Feb 18, 2012 | 03:01 PM
With my br tbe, i was more worried about it coming apart with it being slip on clamps. If they were new when you put it all together, you shouldnt need new clamps. The only other thing that many ppl would suggest, is to weld it ever so thin that you could take a dremmel saw to it to brake it off if you ever need to pull them apart
Old Feb 18, 2012 | 03:53 PM
njboy's Avatar
Crank it down with an impact wrench. It's the only way to be sure. Also Permatex muffler joint compound will help seal it up. I hate exhaust leaks.
Spins_All_4
Aug 25, 2012 03:09 PM
FameEvo
Apr 28, 2012 06:01 PM
IveyTuneX
For Sale - Part Outs
17
Mar 28, 2012 01:27 PM
manatabrian
Oct 13, 2011 09:47 PM
tjsadler
For Sale - Wheels / Tires
Jul 16, 2011 09:15 PM
