LICP blowing off... ah...
Old Feb 22, 2012 | 10:53 PM
sadevoowner's Avatar
Hey Guys -
I know there's a few threads about this already so ill try to keep it short.
Ive had my MR a month now and it has all injen intercooler piping and intake, but it has the mesh hoses that connect from the intercooler to the piping.
This has blown off three times in the last two days.
Ive read hair spray and t boldt clamps to solve this problem... but...
should i order some sort of hose that replaces the mesh hose?
Whats the difference between regular silicone hoses and the reinforced silicone reducer hoses?
Id like to fix this problem asap as its my daily driver and not being able to go over 4k rpm's is a *****.
Also i dont know what size hoses to order? are they 3" hoses or 2.50/2.75? and how long?
Im a noob and appreciate the help!
Old Feb 22, 2012 | 11:04 PM
sujinX's Avatar
i've never had my mesh hose blow off and its all stock stuff. are you sure u tightened them down? t-bolt clamps work really well but if u dont tighten them down they dont work. measure the OD of your injen pipe and get the coupler for that. im guessing its a 2.5" with the limited info. reinforced is usually for high temps. u dont need a reducer if your licp is the same OD as your innercooler. this is BASIC stuff, logical stuff. if u know theres a few threads already, go look for them.
if its blown off 3 times in 2 days, thats user install error. u dont hear everyones evo having pipings blowing off 2 times a day.
Old Feb 22, 2012 | 11:05 PM
I have the regular clamps, and when it gets to a certain point it just keeps spinning, so im guessing its broken and I need a new one?? I heard u lose a little power with the mesh hoses too.
Old Feb 22, 2012 | 11:08 PM
sujinX's Avatar
mesh ones expand under boost. so u lose power.
Old Feb 22, 2012 | 11:11 PM
TheKidd113's Avatar
I really suggest you have t-bolt clamps for all your intercooler piping. I would upgrade your mesh couplers to silicone ones ASAP as the mesh ones expand where as the silicone hold pressure better.
Old Feb 22, 2012 | 11:13 PM
sujinX's Avatar
^^^ he said he has injen licp with mesh (stock) couplers. the mesh is blowing off with the worm clamps.
he must be pushing a ton of boost or something to be blowing those off.
Old Feb 22, 2012 | 11:47 PM
Hendrixmx's Avatar
if the clamp keeps spinning then the clamp is busted. Get some T bolt clamps! The mesh coupler should be fine.
Old Feb 22, 2012 | 11:51 PM
civicej8's Avatar
and a big problem is if you have a aftermarket downpipe thats not wrapped it will heat up the stock coupler to blow off. no joke i heat wrapped my downpipe and wrapped by licp piping with foil and its held up fine.
but really i would try and get rid of the stock couplers asap
Old Feb 22, 2012 | 11:57 PM
Rmeister007's Avatar
Upgrade to the silicone hoses and when you install them make sure it's on both sides equally (equidistant amount of coupler length for both sides). Then tighten them down as much as you possibly can. I had the same problem with my UICP, and it was cuz one pipe wasn't on equally so it was easy for one side to pop off. GL
Old Feb 23, 2012 | 12:17 AM
How do I know how long these silicone hoses need to be? do i just buy a long *** one and cut it down to the lengths I need? Do you know what size I would get?
It looks as if its not even like you said, and i think my clamp is definitely busted because it keeps spinning.
Im not boosting anything out of the normal, the only mods my ix has is, injen intake and intercooler piping, and fajitsubo exhaust, no down pipe or test pipe.
I bought the car pretty much how it sits. I do think it was modded previously because the 2step is set to 6200 rpm's and it did come with the mods plus a harness bar.
Old Feb 23, 2012 | 12:19 AM
btw i appreciate all your responses everybody. ive only had my evo 3 months and am trying to learn everything I can. I have the injen intercooler piping, what kind of piping does the stock evo come with, rubber?
Old Feb 23, 2012 | 12:43 AM
also what size tboldts do i need?
Old Feb 23, 2012 | 06:19 AM
gpfury86's Avatar
If you have 2 1/2 inch piping buy 2 1/2 inch t-clamps...... Not to sound rude, but you just have to use some common sense. If your using hose clamps and tightening one down and it starts just spinning the worm screw without tightening down obviuosly it has a high chance of blowing off. Also when u get t-clamps DO NOT TIGHTEN THEM DOWN AS TIGHT AS YOU CAN, especially if you're using a rachet or an end wrench. If u have injen piping it's aluminum and with t-clamps u have a huge mechanical advantage over hose clamps. So yes tighten them down tight, but it's possible to crush your piping with them so just use common sense. Any tuner shop is gonna have the silicone couplers and t-clamps.
http://www.google.com/products/catal...d=0CHgQ8wIwAA#
Old Feb 23, 2012 | 09:02 AM
okevolutionVIII's Avatar
ExtremePsi has a full T-bolt clamp kit for an Evo 8/9. That's what I bought.
Old Feb 23, 2012 | 09:30 AM
06MRericctho's Avatar
you can get tbolt clamps off ebay for like 40 bucks, that's where I found mine and works great. Comes in a complete set and tighten it to the point where it starts to sink under the couplers. I had the same problem as you but mine never popped off, but the screw kept spinning. Just becareful how tight you tighten it cause I kinda crushed my intake pipe a bit.
