3rd grinding noise
Old Feb 27, 2012 | 10:14 PM
techghost's Avatar
Thanks.
What else do you suggest me to change while getting 3rd gear synchro changed?
Also what could be the consequences for not changing and keep running a bad synchro?
Old Feb 28, 2012 | 06:02 AM
boostaddikt's Avatar
This is a problem I have but it's also 5th gear.... Common problem...Jacks trans says evo 8-9 units have suffered from premature 5th gear wear that will cause grinding.... Anywho.... They found synchro ring stops are too thick and will not allow for proper contact with slider teeth... Idk, I just drive mine like it is, I'll have it rebuilt later on... Google your problem, it's common
Old Jun 27, 2012 | 12:35 AM
techghost's Avatar
UPDATE:
I changed all oil again; this time i've used REDLINE LIGHT WEIGHT shockproof (blue bottle), diaqueen for tcase/diff and Castrol Edge sports 10-60W.
Believe it or not i dont have this grinding anymore
Old Jun 27, 2012 | 06:42 AM
Alpha X's Avatar
My 10 does this all the time... I think all of them do actually :/
Old Jun 27, 2012 | 06:54 AM
DSMolition's Avatar
Originally Posted by techghost
UPDATE:
it’s totally gone even at redline and fast shifts? higher rpm's?
Old Jun 27, 2012 | 07:12 AM
True Blue's Avatar
Wow, if that's the case I may have to give that a go. My third does the same, quick shifts (or cold shifts) into third and it feels like the stick is "knuckling under", probably the same thing as the grind. A gentle press in will yield no grind. It's been that way since I bought it.
Techghost, how long has it been since you put the new fluid in?
Old Jun 28, 2012 | 03:18 AM
techghost's Avatar
DSMolition Quote:
UPDATE:
Yes! its gone completely not even there at high RPMs.
I had this issue since i bought this car, previous owner said that he used Mobile gear oil as soon as i bought my car i changed all oil to OEM mitsubishi oils but grinding noise increased. it started to come even when i downshift to 3rd from 4th.
Last week i changed my all oils again and this time i used redline shockproof.... and BANG!!! its smooth as silk
a week already
Old Jun 28, 2012 | 05:34 AM
kanovic's Avatar
Where did you buy it at? From what I read they said it not recommended for synchros
Old Jun 28, 2012 | 06:25 AM
DSMolition's Avatar
I have to try this soon. Mine grinds into third only when I’m shifting fast and at higher rpms. sometimes feels like it does not want go in (when at the track).. Where did you order the fluids?
Old Jun 28, 2012 | 02:36 PM
jsayers's Avatar
http://www.customcarscentral.com/rdl...w#.T-zN95H4LuY
this stuff?
Old Jun 28, 2012 | 04:17 PM
tlon19's Avatar
does it still grind when your double clutch?
Old Jun 29, 2012 | 05:08 AM
DSMolition's Avatar
what did you put the Castrol Edge sports 10-60W in?
Old Jul 3, 2012 | 07:54 AM
True Blue's Avatar
Bump - how's the Shockproof, still holding? Even if I have to swap it out twice a year, if it prevents the grinding I'm on it.
Old Jul 5, 2012 | 12:52 AM
techghost's Avatar
yes its still holding and i'm loving it. i use to have problems in getting my car in first gear when i wanted to downshift at speed on 10km but even that is gone now. Gearing is smooth
^^ yes this is the one i've used.
@tureblue
I'm not sure if this will work for you or not i think this depend upon the condition of synchro as well if they are in bad shape or gone completely then shockproof will not be able to remove this grinding.
In my case it worked; i never ever used redline gear oils before in any car. Very much satisfied with the outcome
Old Jul 5, 2012 | 05:13 AM
DSMolition's Avatar
ok i just orderd this and diaqueen for my t case and rear end.
Ill report back if it helps me.
