Car shut down
Old Feb 25, 2012 | 05:27 PM
jdr7919's Avatar
Car shut down
So today I was driving my car I came to a red light. I pulled out and the car kinda bogged like I blew off a coupler; but I was driving normally.
Pulled over and could not find anything and the car wont start. Later I got the car home and checked to fuel pump because I just installed it a few weeks ago. I checked it thru evoscan and it turned on fine. Threw in the old pump just to make sure and it came on as well. I checked all the fuses and they are good. I pulled the fpr off and turned the car over and got no fuel.
How do I check for spark?
Im thinking it could be the cas does anyone have any idea?
How hard is it to change the cas?
Thanks
Old Feb 26, 2012 | 02:05 PM
jdr7919's Avatar
Anyone have any thoughts?
I read something about switching the two cam sensors
Old Feb 26, 2012 | 03:43 PM
AJCaron12's Avatar
Don't start throwing parts at it unless you're sure of what the problem is. Do you have any codes? Did you even check fuel pressure? To check spark, you need a spark tester.
Old Feb 26, 2012 | 03:49 PM
jdr7919's Avatar
Update: Cam timing lines up. I pulled the 2 plugs that dont have the coil over them and they both have spark.
I pulled off the sending side to the fuel rail and turned the car over and got no fuel. I know the pump is turning on cause I can test it thru evoscan.
Where do I go from here?
Old Feb 27, 2012 | 08:08 PM
AJCaron12's Avatar
So you have no fuel pressure but your fuel pump works? Sounds weird to me, if that were the case, you'd have a massive fuel leak between the pump and the rail.
AJCaron12's Avatar
Did you pull codes?
Old Feb 27, 2012 | 08:12 PM
turbotalawd's Avatar
Your fuel pump isnt pushed in enough in the sending unit or you forgot to install the rubber seal on the fuel pump.
Old Feb 28, 2012 | 06:25 PM
jdr7919's Avatar
I will check those things again.
Im sure the pump was in all the way I took it out and put the stock one back in and got the same results
Evoscan cleared my codes
kpr
14
Apr 24, 2024 12:42 PM
hatesposers
18
Sep 30, 2014 04:41 AM
EvolutionIXMR06
May 9, 2014 04:53 PM
EvolutionIXMR06
Mar 29, 2014 03:52 PM
michaelrc51
Jul 22, 2013 02:57 PM
