Engine Turns, car won't start
Old Mar 12, 2012 | 03:22 PM
okevolutionVIII's Avatar
Originally Posted by Sil'vr-Boi6
Thanks guys. I was finally able to resolve the issue. It was indeed a fuse blown. There was a old thread with exact symptoms as mine. It turned out to be Fuse #8 Engine Control. It simulates defective coilpack, crank angle sensor and fuel pump issues.
Good deal that it's a cheap fix.
Old Sep 27, 2012 | 09:23 AM
144mph's Avatar
Originally Posted by justastockevo
service manual details the diagnostics procedure, so you may want to see it first.
I've got the service manual and can't seem to locate the test procedure for the crank position or cam angle sensors. Anybody have this information?
Old Oct 21, 2012 | 07:37 PM
sbc105's Avatar
yes this seems to b common for some reason i had my engine control fuse pop on me twice so far right as a come to a stop light and the ****ty thing is that it happened in almost the same stop light i was at the first time it popped i have to do more diag work on it to figure out yits doing this?
Old Mar 31, 2013 | 02:46 PM
HeyHenry's Avatar
Sorry to bring back an old thread. My #8 fuse was burnt last night. The problem is that when I replace it with a new one, it gets fried again as I try to start the car. Am I starting the car up wrong? Any ideas?
Thanks.
Old Apr 1, 2013 | 05:20 AM
Sil'vr-Boi6's Avatar
Thanks.
There is no technique in starting the car, it sounds like you have exposed wires somewhere or moisture near some wires. Did you work around any wires lately? any exposed wires under the seat? in dash radio job lately?
Old Apr 1, 2013 | 05:46 AM
4RETECH's Avatar
Thanks.
Yes, you have a dead short in that circuit.
One of my friends did his spark plugs once and dropped the coil pack bolt. he couldn't find it. About 3 months later we found it popping the fuse because it was resting next to the starter wire.
Old Apr 9, 2014 | 07:24 AM
dl100489's Avatar
i would cheak compreesion spark and fuel if you have all that cheak for signal to injectors could also be crank ,cam sensor
Ferp
Jul 11, 2016 08:07 PM
Dynafit
Nov 4, 2015 01:20 AM
L888Apex
Oct 30, 2012 07:47 PM
rockmonkey69
European Forum
12
Aug 16, 2011 02:29 AM
911_Evo
39
May 10, 2010 01:39 PM
