A/C delete guys chime in
Ive been debating about taking my A/C out for a couple months now, just waiting on a good enough time to do so. Dont try to come in here and bash me about how hot my car will be in summer.. yes I already know this because I don't use A/C as it is and thats what windows are for..
But my question is with the A/C compressor, and all the lines removed; Will the fan still blow air out if the temp knob is on the cold setting? I dont care if its cold would rather it not be just dont like sitting at a light or in traffic without wind. Yes I have searched and have not found anything either so a/c delete guys let me know!
I deleted my ac a while back, def worth it if you don't use it. More space and just makes the engine bay look cleaner. As far as your question goes I believe it will only blow hot air. I could be wrong haven't tried to use it in the cold setting. I'll check when I get home lol
It should still blow, it just wont be refrigerated air. the defrost wont work as efficiently since it uses the a/c compressor to dry the air in the cabin. That is my only complaint and a minor one at that for me. I also never used the a/c in my car and that is why I deleted mine.
Sweating is good for you anyways
just gonna be screwed if my window motors go lol
But about the defrost, does it still use the compressor even when the temp knob is on heat? I might run into problems doing this but nothing major because I turn the defrost on 4 to help warm up my car so basically that wouldn't be doing anything for me anymore huh?
thats what Im talking about.. Never using a/c for a cleaner engine bay is def worth it.
Thanks! About how long did it take. Obviously the time difference will be present because so many variables but just trying to plan for a couple hrs vs. a whole day event
alright, let us know what you figure out..
Yes sweating is a plus especially when your trying to impress the ladies
The way the defroster works is that the compressor comes on to dry the air. This is how it gets rid of the fog in your windshield. WIthout it it wont be very effective. With the temp on heat the compressor does come on, but if you delete it obviously it wont anymore.
You should still have heat, just think of it as not being de-humidified heat, as that is what the compressor does in a sense.
depends on how in depth. You have to suck out the refrigerant which takes a few minutes. If your just pullng the compressor off then it takes maybe an hour. I cant remember if I removed my radiator or not to do it. I actually deleted the compressor, the a/c bracket, the high and low side lines, and the condensor. I also covered up the open lines in the firewall with a plug. That took a few hours only cause I was taking my time and didnt want anything to get scratched as I had a buyer for my a/c parts lined up.
Would having a lift make taking this off any easier?
Like everyone else said it just blows are like if you were using a fan & taking it off is easy. I just used jack stands, lifted the front up & took my front bumper off so I had more room.
The compressor is only 4 bolts, the compressor bracket is 1 bolt I think. I canT remember if I took out my radiator to pull the condenser. The lines are easy to take off as well.
You'll need a smaller accessory belt also, got mine from STM for $40 I believe
yea you still have heat or "cool" air on the cold setting. the defroster sucks without a/c but is not completely ineffective. its very hot in the summer especially in a 9 with all black interior. on the bright side the car is lighter, the engine bay is cleaner, and the a/c / defrost does not make the car idle high and awkward with big cams. worth it in my book
How hard is to install the accessory belt back on?
