Aem wideband readings..
Old Mar 21, 2012 | 02:13 PM
500evo's Avatar
I have installed my wideband today, on idle its showing 15.5-16.5 and when i drive its at about 14.3-15.2. Is this running rich? Or is that normal ?
Old Mar 21, 2012 | 02:23 PM
500evo's Avatar
The mods on the car are Ams fmic, Ams licp, Ams uicp, Ams batter kit, Injen Intake, Ebay header, Ams Full Turbo back exhaust, hallman bc...
Old Mar 21, 2012 | 02:33 PM
greencow's Avatar
No tune?
That's a bit lean at idle. 14's to mid 15's what you want at idle. Cruising seems about right. What do you hit under WOT? That's really the most important thing.
Before my tune, I was hitting 10ish under WOT. Way to rich. Now I'm around 11.5-12ish under WOT, no knock counts. My mod list looks similar to yours.
Old Mar 21, 2012 | 06:20 PM
slowonder's Avatar
i have ???? bout this too. i installed my LC-1 the other day and idle is find 14.7-15 but cruising is at 13.8-14.2.... now the other two cars ive had widebands in were around 14.7 cruising... seems a bit low to me. under wot with the mbc set to 23 pounds its around 10.9-11.5 and thats without a tune......
grimmspeed boost controller, busher full turbo-back, busher intake and evo 9 dv
Old Mar 21, 2012 | 08:08 PM
500evo's Avatar
Idk what its under WOT havent checked it yet. On the other hand i just messed my car up, something blew when i switched from 1 to 2 gear the car just like turned off, idk wth happen. Car can turn on if i keep hiting the gas when i let go it turns off. Can someone help please.
Old Mar 21, 2012 | 08:22 PM
500evo's Avatar
Please close this thread mods :[
Old Mar 21, 2012 | 08:33 PM
greencow's Avatar
500evo - did you check to see if you blew off a hose? Common areas are the licp connector, and the throttle body connector. I was blowing that one off constantly, until I put bolt clamps on.
Slowonder - did you do the open air calibration? Evos run pig rich from the factory, especially under wot, and with mods it just gets worse. You need to get a tune done. Afrs will be much better after that, more power, better mpg under wot, and the car will pull harder and smoother thru the gears.
Old Mar 21, 2012 | 08:36 PM
500evo's Avatar
Yea man I checked this car is giving me a HUGE headache.
Old Mar 21, 2012 | 08:50 PM
stroked4g63's Avatar
make sure its calabrated properly......
Old Mar 21, 2012 | 09:50 PM
500evo's Avatar
The car stoped on me in the middle of the road, I turned it on and drove it home I also drove it over 20mph, When i came to a stop it just turned off, so the car runs when it is moving.
Old Mar 21, 2012 | 10:57 PM
slowonder's Avatar
cars never got good gas mileage. only thing it came with was an exhaust. my 1.8t jetta was 35+mph my wrx was 27+mpg and this thing is VERY consistant on 20.7mpg lol. doesnt matter how much i beat on it or dont beat on it. the mods havent changed it at all. even removed my rear wing to see if that would do anything since i drive alot of highway but noda. i just figured i may have a leak with the low a/f readings while cruising. yes i did the install and cal by the book.
Old Mar 22, 2012 | 05:02 PM
awdordie's Avatar
if you were researching cars for great gas mileage and you bought an evo you didnt do your homework good enough. i seriously get tired of hearing complaints about gas mileage in these cars when you should know performance and economy are two completely different things when buying a car. 4 doors doesnt necessarily=great gas mileage.
Old Mar 22, 2012 | 05:14 PM
mitsumonster03's Avatar
^^^^ true that man!
Old Mar 22, 2012 | 09:00 PM
slowonder's Avatar
i understand that. the mileage doesnt bother me. just threw me a curve ball when the po said he was getting 25mpg most of the time. cant say performance and mpg doesnt fit when most the srt-4's with over 500whp around here are seeing over 30mpg or my buddys c5 corvette gets better mileage than me or the other vw's ive seen get over 30 too. i understand these dont get good gas mileage thats not why i bought the car. i just find it weird how SPOT on it is every tank no matter how i beat on it. if i wanted mpg i would of just built the hell outa my vw.
Old Mar 24, 2012 | 12:01 AM
FJF's Avatar
FJF
kyoo
Jun 30, 2019 12:44 AM
Lombardi23
Apr 22, 2016 08:15 PM
Evo1001
Jul 22, 2011 09:25 PM
jimm
16
Jul 1, 2011 06:43 PM
svt_lightning01
Apr 18, 2011 12:26 AM
