vibrating question?
Old Mar 24, 2012 | 11:45 PM
sest1412's Avatar
vibrating question?
New to the forum just wanted to know if any one has the same problem as my 03 evo, on the freway there is a vibration inside the whole cabin when i shift to 5th gear at 55mph it starts until 65mph it kinda goes away, its like its not in the right gear yet i dont know if thats normal this is my first evo and mitsubishi also what should i do any help is apreciated.
Old Mar 25, 2012 | 08:08 AM
cfdfireman1's Avatar
how about 4 gear at that speed?
Old Mar 25, 2012 | 08:10 AM
DeFog's Avatar
Kind of hard to diagnose, could be a number of things really, I would suggest checking all of you're suspension components/system, how do your tires look?
Old Mar 25, 2012 | 09:35 AM
lanberg's Avatar
does this happen at other gears if u are going too slow and in a high gear??? What are ur RPMs at in 5th gear at 55?? You may need new spark plugs, but thats a basic diagnosis.
Old Mar 25, 2012 | 10:04 AM
marcusE's Avatar
Check for small animals.
Old Mar 25, 2012 | 10:06 AM
sest1412's Avatar
it only happens in 5th gear, i havent checkt my spark plugs how do i check my suspension ill post rpms later when i get of work tires are 50% thread all gears are good exept 5th when i hit 70 it goes away kinda havent passed that speed, thanks guy i feel realy welcome here coming from the jaguar forums
Old Mar 25, 2012 | 11:04 AM
barneyb's Avatar
Some say rebuilding the tranny with new bearings is the fix. My car started doing this just after I replaced the OEM tires. So, that would be in the low teens. I now am pushing 80K. Other than the vibration, my tranny is still good.
Old Mar 25, 2012 | 05:05 PM
If it's not speed related and it doesn't vibrate at that speed in a lower gear I have to say it's your trans. 4th gear will take you to well over 100 MPH so don't be afraid to try get it up to 70.
Old Mar 25, 2012 | 11:34 PM
sest1412's Avatar
so in 4th gear at 55mph its at 3500rpm i got to 70mph in fourth gear and then shifted to fith gear i could verly hear or feal the vibration, so every one says its the tranny so i should take it to a tranny shop there is an aamco shop here in town but there is no mitsubishi dealer here in reno, nv thanks for all the replies.
Old Mar 26, 2012 | 02:42 AM
CDHoff's Avatar
My car used to vibrate at higher speeds then I got Spoolinup cop and new tires and the problem was fixed. Not sure which one fixed the virating since they were both installed at the same time but my guess would be the tires.
Old Mar 26, 2012 | 08:42 AM
sest1412's Avatar
excuse my ignorance but what is a Spoolinup cop i dont know what that is.
Old Mar 26, 2012 | 09:18 AM
Evo_Jr's Avatar
Search bud. or have your flame suit on
http://www.spoolinup.com/
Old Mar 26, 2012 | 10:37 AM
OfaceGrimmins's Avatar
Could be axles causing this too. my 2 cents
Old Mar 26, 2012 | 01:40 PM
Simply question, does it vibrate at all in any other gear beside 5th at 55 to 70?
Old Mar 26, 2012 | 02:45 PM
sest1412's Avatar
in 5th gear at speeds of 55 to 64 pmh at 70mph belry hear it o feel it any other gears it does not happen thanks again guys
