ACT clutch problems..go figure.
Old Mar 28, 2012 | 02:39 PM
12secDD's Avatar
I recently had an ACT MB7-XTSS clutch installed. Sprung, full face disc. And when I shift at redline, more than half the time, it'll lock me out of the gear.
Other than buying a twin disc, is there any modifications I can make to correct this? Right now I have solid shifter bushings (underhook and base), STS, AMS SSB clutch lines, to compliment the clutch.
Old Mar 28, 2012 | 02:47 PM
fostytou's Avatar
EvoM Community Team
Have you done the front lower motor mount? It almost always solves this problem especially as they get older.
Old Mar 28, 2012 | 03:16 PM
12secDD's Avatar
No, still using the stocker.
Old Mar 28, 2012 | 04:29 PM
Hendrixmx's Avatar
+1 noticed a huge difference in drivability when i changed this mount. Helps alot in regular daily driving as well. Makes engaging the clutch much easier.
Old Mar 28, 2012 | 06:03 PM
Search this topic. It is a very common issue w/ ACT which I have as well. I dont shift at redline (too often) so I just live w/it.
Some lock out issues can be resolved w/a simple clutch pedal adjustment which you should have done. ( I havent adjusted mine yet)
Old Mar 28, 2012 | 06:28 PM
Dallas J's Avatar
Veteran: Army
Does your clutch engage near the floor or towards the top?
Old Mar 28, 2012 | 06:32 PM
High_PSI's Avatar
Motor Mounts, the engine rocks a LOT. Also adjust the clutch further out, it may not be fully disengaged.
Old Mar 29, 2012 | 10:51 AM
dastallion951's Avatar
if you dont wanna do the motor mount, i also noticed a shifting improvement when i swapped in a engine torque dampener, i used the ingalls kit. Shifting got a lot more crisp and less notchy.
Old Mar 29, 2012 | 08:56 PM
12secDD's Avatar
I would say in the middle. The shop that installed it did not adjust the clutch pedal, that i know of.
I ordered a set of torque solution solid mounts yesterday. All but the rear mount.
Old Mar 30, 2012 | 12:55 AM
superkizuna's Avatar
MB7-HDSS, no lockout at all. I don't just drop redlines I slip n drop them though. I'm also probably making less torque than you. With your setup you might roast my street clutch.
Old Mar 30, 2012 | 07:40 AM
Dallas J's Avatar
Veteran: Army
Its really easy to adjust, I would suggest getting the engagement higher. That will help get more separation between the flywheel and pressure plate giving more room for the "wobble" of the disc.
Another issue that may cause the binding is if they didnt clean out the splines and put a bit of light grease on it (very light of course). If not then the disc can stay rubbing against the flywheel instead of floating off it cause a little excess drag.
On all my clutches if done (dozens if you include DSMs), getting enough separation and having good detailing on the splines has always given me great shifting.
Old Mar 30, 2012 | 08:51 PM
12secDD's Avatar
I'm going to see if these mounts fix it. If they don't, then i'll bring the engagement point out a little.
Thanks!
billybond_09
39
Feb 8, 2020 06:58 AM
martinPL
Jun 1, 2016 09:22 PM
Clipse3GT
Oct 1, 2015 07:17 AM
gr8stevo
Sep 1, 2015 12:06 AM
doncarbone
Jan 4, 2014 10:24 PM
