How important is the bracket for the intake manifold
Old Apr 10, 2012 | 09:30 AM
EVOWRC111's Avatar
I have a lot of upgrades to do and a lot of my friends that also own evos say to leave the bracket to the intake manifold off due to it being so difficult to get to. Is this a bad idea? Im sure it gives the manifold support but is it necessary? For better measure, I'm running a FP Black with supporting mods. This means higher boost pressure and harsher conditions. Thanks guys
Old Apr 10, 2012 | 09:41 AM
blknblubkrdude's Avatar
I have not heard of any issues relating to a removed bracket. I personally left mine off when I replaced my IM with a Rev3.
I believe if you torque to spec and use a dab of blue Loctite there will be no issues.
Old Apr 10, 2012 | 10:00 AM
tsidrift1's Avatar
Took mine off when the new motor went in. I never ran one on my dsms in the past either, never had any issues.
Old Apr 10, 2012 | 10:24 AM
EVOWRC111's Avatar
Thanks guys, this is sounding good.
Old Apr 10, 2012 | 10:45 AM
Supergoslow's Avatar
Im in the process of rebuilding my engine and I was wondering the same thing. It wasn't fun taking it out, thanks for posting
Old Apr 10, 2012 | 10:52 AM
EvoFredo's Avatar
left mine off after pulling the mani for egr delete , been running it that way for over a year. makes it a lot nicer to be able to reach down their withought a bracket in the way. Plus most aftermarket intake manifolds dont come with supports.
Old Apr 10, 2012 | 10:55 AM
mdsevo06's Avatar
Especially the Knock Sensor.
EvoHung's Avatar
They add a lot of precaution from the factory to cover their own a$$ if something was ever to go wrong. However, those precaution's are usually over engineered and provide VERY minimal improvements to justify keeping.
Old Apr 10, 2012 | 04:17 PM
jayg4u's Avatar
Veteran: Air Force
I never had one on my car...no issue.
Old Apr 10, 2012 | 06:16 PM
GTijoejoe's Avatar
most likely the brkt is there to stiffen the joint to prevent torque loss on the manifold by reducing the vibrations etc....
Old Apr 10, 2012 | 06:20 PM
foxbear2277's Avatar
Removed it when I installed my magnus manifold, wont work with it. Highly doubt its of great importance... best advice is remove for scrap metal or paper wait
Old Apr 10, 2012 | 07:11 PM
turbotalawd's Avatar
This +1. The bracket is not necessary.
Blue Evo 8
21
Dec 6, 2016 01:06 PM
shomesomesho
Sep 5, 2015 06:02 PM
joseph143
Feb 19, 2014 07:42 AM
miller121mx
Apr 9, 2010 12:03 PM
kaymin
Jan 7, 2010 10:41 AM
