Wideband question
Old Apr 10, 2012 | 08:19 PM
MaDD-Myke's Avatar
Wideband question
just install a AEM wideband in my evo 8...whats a good reading when in idle....in boost......and just crusing.....
Old Apr 10, 2012 | 08:28 PM
gpfury86's Avatar
On pump or e85
Anywhere from like 14.5-15 for idling and cruising and WOT u shouldnt be anything over like 12 optimum would probably be around 11.5 or so. For e85 should be a bit leaner. like 12-12.3 at wot or so.
Old Apr 10, 2012 | 09:15 PM
06RedRalli's Avatar
^That.
Old Apr 10, 2012 | 09:20 PM
MaDD-Myke's Avatar
on pump gas.......
Old Apr 11, 2012 | 12:42 AM
sujinX's Avatar
14.5-15.x at idle. and roughly 11.5 or so at WOT.
Old Apr 11, 2012 | 06:36 AM
Evo_Jr's Avatar
What if my car runs super lean at WOT? 16 on the spot. The car pulls, and runs great.
Old Apr 11, 2012 | 11:36 AM
06RedRalli's Avatar
Stop doing WOT pulls if it's at 16, that is wayyyy lean. Needs to be like mentioned in the 11.5 range if on pump gas.
Old Apr 11, 2012 | 11:39 AM
Drifting Away's Avatar
Whoa you need a retune my friend, what gas is that on? And the car can run better than what you think its running if its hitting 16AFR at WOT. How long has it been on this tune?
Old Apr 11, 2012 | 12:12 PM
Evo_Jr's Avatar
Wow good thing I asked. The car has been tuned like this for about 2 months. I recently went back to the tuner because my boost levels were switched from each map. (pump gas/e85)
This has been on E85. I've noticed it running like this recently the past couple of weeks. I don't do a lot on WOT, but noticed it on the highway when I want to gain speed, onto ramps, etc.
I'll be contacting my tuner this weekend. Thanks guys
Old Apr 11, 2012 | 01:28 PM
Boostd4's Avatar
Could be the sensor thats screwy...16 AFR at WOT = Esplosion. I would double check the gauge and O2 sensor for the gauge as well as getting that tune triple checked.
Edit: Also might be a leak somewhere ahead of the Wideband sensor...resulting in a lean reading. Just a few thoughts...
Old Apr 11, 2012 | 01:36 PM
evo8426's Avatar
I was thinking maybe he had an exhaust leak
Old Apr 11, 2012 | 01:56 PM
Evo_Jr's Avatar
Umm. I believe it may be a bad o2 as well after watching the AEM Wideband o2 sensor video posted in another thread. I went for lunch today, and noticed it was over in 10-11AFR.
What gets me is that the sensor has no more than 2k miles!
OP, sorry didn't mean to thread jack. Thank you guys for the info!
Old Apr 11, 2012 | 02:37 PM
gpfury86's Avatar
Ya at 16 it's not gonna take long to break spark plug electrodes and blow stuff up!
Old Apr 11, 2012 | 09:53 PM
MaDD-Myke's Avatar
thankx for the posts guys
Old Apr 12, 2012 | 10:14 AM
cz1's Avatar
cz1
11.4 WOT is about right.
