Is E85 worth it.
Old Apr 12, 2012 | 07:22 PM
  #31
vmrevo9's Avatar
Veteran: Air Force
you can have your tuner set you up with a dual map setup and you can either use a switch, gas pedal or intercooler switch to switch between maps with out having to hook up your laptop.
has anyone had issues with the gunk collected in the injectors?
Old Apr 12, 2012 | 07:27 PM
  #32
clubchico15's Avatar
Originally Posted by evo8426
yes your fuel set up will be fine, i run pte 1200 and walbro 255
Thanks for the info... SD & E85 coming soon!
Old Apr 13, 2012 | 07:34 AM
  #33
SmurfZilla's Avatar
Cobb AP for the Evo 8/9 is useless anyways. No one was buying so that made smart business sense.
There are a ton of ways to get the switching done. Haven't experienced the gunk build up yet. But i have been using a combo of Lucas E85 injector cleaner and pump gas once in a few tanks.
Old Apr 13, 2012 | 08:40 AM
  #34
Alpha X's Avatar
Originally Posted by Boostd4
Going E85 is definitely great for power, I think they key thing you'll need to consider is availability. The ONLY reason why I haven't done it yet is because it's a pretty inconvenient trek to get E85...although it is available, I just can't justify it...yet.
Same situation for me. I would love to covert but if I want to take a trip and E-85 isn't available I'm screwed
Old Apr 13, 2012 | 09:22 AM
  #35
evo8426's Avatar
That is why you keep your pump gas tune and just switch when needed
Plan trips in advance so you can switch fuels, I used to take 10 gallons extra with me and I've made 400+ mile trips no problem.
Old Apr 13, 2012 | 10:18 AM
  #36
novik7's Avatar
well thanks for your inputs! i can understand that e85 will make more power and you can add more timing. They biggest debate for me would be is the availability and have to get bigger inejctors be worth it. Long story short im not trying to go past 500 on stock block either way.
moparfan
Aug 4, 2016 07:11 PM
sik_z33
Jun 20, 2016 08:08 AM
Randal
E85 / Ethanol
29
Jan 19, 2015 07:06 PM
Mikami
Sep 27, 2014 05:28 PM
SLDEVO
Jul 15, 2013 07:03 AM
