Wanting to make the switch to E85
Old Aug 16, 2013 | 09:01 PM
Randal's Avatar
Guest
Hi guys, I am wanting to make the switch to E85 but just have some questions. I have a 2003 Evo 8 with 103k miles. My current mod are Intake, exhaust, cams, cam gears, upgraded intercooler, 750cc injectors, walbro 255 fuel pump and a Tomei arms m7960 turbo. I am currently making about 330Whp. I will be getting Precision 1200cc and a E85 tune from AWD Motorsports. My question is will I be able to reach 420-450 WHP Reliable with current mileage reliably?
Old Aug 17, 2013 | 01:05 PM
CDrinkH2O's Avatar
You should be able to hit 420 whp easy. Ask your tuner to keep torque below 375 when the turbo hits for reliability and you'll be fine. I pushed it over 400 wtq on a stock bottom end and blew my # 2 big end bearing out at 80,000 miles. If you want more then build it!
Old Aug 17, 2013 | 02:26 PM
Drew1's Avatar
Reliability = How much do you beat the car?
If you just do some pulls here and there or some canyon runs or whatever light it should be fine but if you are tracking and running it into the ground then engine might go out a little sooner than later. Maybe do a compression test as well. E85 in general is pretty safe to run and runs cooler with a lot of knock protection.
Old Aug 17, 2013 | 02:34 PM
MaLo EvoVIII's Avatar
Did you get tuned today?
Old Aug 18, 2013 | 02:52 PM
Randal's Avatar
Guest
No I did not, maybe in a couple of months.
Old Aug 18, 2013 | 02:53 PM
Randal's Avatar
Guest
This is only for roll racing at my local track and I don't beat my car at all. I don't track it if you mean by laps. I only like straight lines.lol
Old Aug 19, 2013 | 05:07 AM
I'm confused. In another thread you mentioned that you have been making 452 whp on E85 for 3 years without any issues.
https://www.evolutionm.net/forums/ev...i-m7960-2.html
Post #16.
Old Aug 20, 2013 | 04:06 AM
Randal's Avatar
Guest
Post #16.
Yes sorry lol , it's not actually my car is my wife's Evo , we purchased it from a friend a couple of months Ago as is. My evo is the one I want to make the switch to.
Old Aug 31, 2013 | 03:45 AM
JaYr_EvO9's Avatar
Once you go e85...youll never go back to pump gas !!!!!! lol :-)
Old Sep 5, 2013 | 05:39 AM
ChaiseM13's Avatar
Im curious about this. I just spoke to Dan @ AMS and he told me to stay away from E85 and sent me an article about it. Wanting to make the switch for the obvious reasons: more power and cheaper at the pump! Any suggestions?
Old Sep 6, 2013 | 03:38 AM
Randal's Avatar
Guest
I went all out pure E85 but you can also get a dual map for like $100 more so you can run E85 or Pump gas. I don't regret it, I just made the switch a couple of weeks ago and it's amazing.
Old Sep 6, 2013 | 06:44 AM
ReaperX's Avatar
Mind sharing that article with the rest of us?
Old Sep 7, 2013 | 06:51 AM
Drew1's Avatar
Ya interested why to stay away from E85. I know some people believe it eats fuel lines but I've never seen a case of that. The fuel savings are negligible since you lose about 20% of your fuel economy on average just using E85.
Old Sep 9, 2013 | 09:35 AM
egis's Avatar
[QUOTE=Randal;10948360]I went all out pure E85 but you can also get a dual map for like $100 more so you can run E85 or Pump gas. I don't regret it, I just made the switch a couple of weeks ago and it's amazing.[/QUOTE
that's right.Devin from boostin told me to switch between maps once in 3 months to keep injectors clean and you good to go.
Old Sep 10, 2013 | 05:16 AM
ChaiseM13's Avatar
Sure, here you go!
http://www.injectordynamics.com/AlcoholArticle.html
