more issues
Old Apr 12, 2012 | 07:39 PM
Ragin-Azn's Avatar
more issues
Well i figured out my lean at idle issue. My o2 housing bolts backed out and i had a leak. I fixed that with lock washers. But now under full throttle my cel flashes and it feels a lil sluggish. I changed my plugs and checked all my pipes and vaccum hoses and they looked good. Any idea what it could be?
Old Apr 13, 2012 | 04:10 PM
dootwah527's Avatar
Not sure if its been flashed or not, but if thats the case then it might be knocking, triggering the CEL flash, resulting in the ecu pulling timing?
Just throwing it out there
Old Apr 13, 2012 | 04:49 PM
Murf's Avatar
^^ that. Tephra mod. Knock cell flash.
Old Apr 14, 2012 | 12:00 AM
tstevens's Avatar
Car been tuned? If so it may have Tephra flashed where the CEL flashes with knock. If not, can you pull any codes? Could be a variety of things, MAF, Knock, etc.
Old Apr 14, 2012 | 12:52 AM
Ragin-Azn's Avatar
Has been flashed and it does flash when spark knocking but usually only when cruising at low rpm. Once i mash it everything is good and it yanks. But now mashing it makes it worse. It flashes the whole time its mashed
Old Apr 14, 2012 | 12:55 AM
Ragin-Azn's Avatar
Thr cel doesnt stay on so i don't get any codes when using a scanner.
Old Apr 14, 2012 | 01:18 AM
grim~'s Avatar
You check your plugs and gap?
Old Apr 14, 2012 | 05:50 AM
Ragin-Azn's Avatar
Put them in Wednesday and i gapped them before putting them in
ES Lancer
Lancer Troubleshooting
Jan 28, 2016 07:28 PM
Jehuty
Jul 9, 2015 01:08 PM
hysteria.h
Aug 10, 2012 10:43 PM
Jehuty
Lancer Engine Tech
Oct 23, 2011 08:14 PM
Still_Spinnin
Jun 23, 2010 01:00 PM
