test pipe
Old Apr 12, 2012 | 08:16 PM
evo854880's Avatar
Exclamation test pipe
will removing my cat and installing a test pipe make my service engine light come on? i will still have all of my o2 sensors in place
Old Apr 12, 2012 | 08:23 PM
okevolutionVIII's Avatar
Yes
Old Apr 12, 2012 | 09:50 PM
evo854880's Avatar
any way around that?
Old Apr 12, 2012 | 09:51 PM
06RedRalli's Avatar
Turn it off using ecuflash and tactrix cable.
Old Apr 13, 2012 | 05:38 AM
2theMAX's Avatar
Buy an O2 extender. Search.
Old Apr 13, 2012 | 07:23 AM
DSMpsi's Avatar
^this
Old Apr 13, 2012 | 09:27 AM
HaVoC187's Avatar
I never had a cel when I removed my cat, guess I was lucky. It only came on when I installed my downpipe aswell.
Old Apr 13, 2012 | 12:36 PM
blknblubkrdude's Avatar
Yes, CEL will turn on.
Mine even came on with a High-Flow Cat.
Old Apr 13, 2012 | 01:18 PM
DJ_2103's Avatar
What exactly do you have to turn off in ecuflash?
Old Apr 14, 2012 | 12:07 AM
tstevens's Avatar
Yes it will throw a code, just get an 02 extender. Moves the sensor back out of the exhaust stream and it won't throw a code. In ECUFlash you can pull your map, scroll down to the DTC/Engine Codes and find the Rear Catalytic Efficiency Below Threshold Code - it also will show up as a P0420 code which may be easier to find. Once you find it, turn the code off and reflash your map.
Old Apr 17, 2012 | 01:52 PM
djdnav's Avatar
^^ this.
It's pretty much the same with every car. Deleting the cat makes the car think the cat is broken since the front and rear o2 sensor readings are almost the same, instead of the second o2 reading lower because of the restriction.
Old Apr 17, 2012 | 03:50 PM
zona7's Avatar
wow .. this is great info, B4 i get my tune and delete my cat
Old Apr 17, 2012 | 04:16 PM
jamesmcquiniff's Avatar
Lol thats awesome
Old Apr 17, 2012 | 07:02 PM
gillis13's Avatar
get the ultimate racing test pipe, it has a built in fix which moves the 02 sensor back. had mine on for about a year now and no codes.
Old Apr 17, 2012 | 07:04 PM
ajnasrah20083's Avatar
A tuner can turn it of. Do whatever you want with the car for now in modifications and make the tune worth getting
