Wing Downforce Specs?
Old Jan 25, 2004 | 12:14 PM
  #76
M3lachsilber's Avatar
choad
Wow..
Great stuff but you missed an important part of the equation..
"10.21 JIGAWATTS..!!!"
My eyes are watering from reading all of this information..
Thought I would lighten it up..
Old Jan 25, 2004 | 02:54 PM
  #77
jasonc32amg's Avatar
The latest review of the new RS mentions that the car is not as planted without the wing above 100 or so and recomends one for high speed track work...
Old Jan 25, 2004 | 09:25 PM
  #78
Hallster's Avatar
Originally posted by Earl Needham
Speaking of which -- it seems to me that you could get a lot more efficiency from the wing at a lot lower speed, if the wing incorporated a leading edge slat and a trailing edge flap, just like a regular aircraft wing. I guess it would add some cost and perhaps that's why it isn't done.
Great idea... indy car teams use a flap on the trailing edge all the time to dial in DF w/o changing angle of attack. How much DF would a particular size correlate to on an Evo? How much drag will it it add? TIA
FYI, I'm going to take my stock Evo to Willow in Fed or March. Willow's such a fast track, DF goes a long way there - the trick is getting as much DF as possible w/o increasing drag to the point were the net is a slower lap time.
Thanks,
Sean
Old Jan 25, 2004 | 09:34 PM
  #79
Hallster's Avatar
The Evo Press briefing doc states the Evo VIII has a .01 better coefficiency or drag than the Evo VII, but doesn't include Evo VIII's COD. Anyone know what the COD on the Evo VII is, or better yet, an Evo VIII?
...Since MMC didn't include the COD for the Evo VIII in the Evo press information doc, my hunch is that its pretty poor... Maybe .034 or greater.... The technical doc includes just about every other salient technical data point but leaves that out. Weird.
Sean
Old Jan 26, 2004 | 05:53 AM
  #80
Earl Needham's Avatar
Veteran: Air ForceVeteran: Marine Corp
Thanks,
Sean
That's something that will probably have to be determined through trial and error. I drive an O-Z, so possibly your wing has a better cross section than mine, but I can tell you that mine has the cross section of a 2 by 10! In other words, I don't think they even tried to get good aerodynamics on the O-Z wing. I'm thinking I'm going to take some fishing line, secure it at the front of the trunk lid, and check out what's happening around the wing. Next weekend, I guess, right now I have to go to Atlanta and back!
Earl
Old Jan 26, 2004 | 06:29 AM
  #81
mayhem's Avatar
Originally posted by djsbadger
While downforce has no mass, it is a force and weight is a force as well. The beauty of downforce is that it pushes down on the car (like a weight) but it does not have to be accelerated and stopped. For purposes of calculations, downforce which is due to pressure acting over an area, can always be converted to a resultant force acting at a specific location. Because the wing is mounted behind the rear tire, it can reduce the load on the front tires in the same way that a see saw works.
I agree. This is what I was *trying* to say pages back but I can't always seem to get my point across using text. Mass(gravity) = Force. Just as I said earlier with a DF on the rear the net weight ratio would be moved towards the rear respectively.
Old Feb 7, 2004 | 06:18 AM
  #82
turboj's Avatar
working or not... EVO's won't be "BAD" without it!
Old Feb 7, 2004 | 10:51 AM
  #83
EVOTEXAS's Avatar
Originally posted by SOF
Try putting a 437 lb weight on the wing, it will break lol.
Again, as previously mentioned, I will repeat, in case you missed the above post, mass and downforce are not the same.
Old Oct 24, 2010 | 11:13 PM
  #84
SpecialNeeds's Avatar
so at 45 MPH is the wing making almost no downforce? it just starts making downforce at above 65?
Old Oct 25, 2010 | 06:00 AM
  #85
Clovis_Man's Avatar
Wow, 6 1/2 years since this thread wound down!
Anyway -- the wing makes little to no downforce at any legal highway speed. Most wings only come into play above 100 MPH, and Indy car racers use 140 MPH as the spot where their wings start working.
Old Oct 30, 2010 | 07:44 PM
  #86
thanks. yes it is an old thread, but a good one
Old Oct 30, 2010 | 08:31 PM
  #87
roadace's Avatar
Definitely an important thread. And 6 years later we still have no hard data. I've been wondering about this for years (i.e. the actual specs for the rear wing.) "Chris in HB" had some helpful points... thanks Chris.
Anyway, anyone have any solid info on this? I'll offer my wing for wind tunnel testing.
Old Oct 30, 2010 | 09:54 PM
  #88
Marroccowned's Avatar
This is interesting about the vortex generator
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
Old Nov 8, 2010 | 03:00 PM
  #89
roadace's Avatar
I'll be doing some reading tonight. Thanks for the info.
Old Nov 8, 2010 | 03:08 PM
  #90
Ryan.Kauz's Avatar
^^ In keeping this zombie thread off topic, and on vortex generators i'll add the following:
"According to the Ralliart EVO MR brochure, the Mitsubishi vortex generator was wind tunnel tested at 180km/h. Vortex Generator Test results (on 180km/h): Rear downforce: + 2kg = 35% UP Air Resistance (CD) : 1.1% OFF" -Quote from a fellow EvoM member.
What we can intone from this:
They are saying "Rear downforce: +2kg UP" and then "Air resistance (CD): 1.1% OFF".
What they are saying is that the rear downforce at the increased speed is increased (UP) by 2 kg (or 4.4 lbs). Since this is a 35% increase this would mean the original downforce was: 12.6 lbs (@180 km/h) and the downforce with the vortex generator is 17 lbs.
Air resistance, Coefficient of Drag (CD), they are talking about the drag coefficient. The drag coefficient is a number that describes the drag a car can have. I say can have because the drag a car DOES have is dependent on it's velocity, frontal cross sectional area, the air temperature and air density that the car is moving through. The drag coefficient is a good number to compare the potential drag a car can have from one to another. From most reasonable sources online that I can see, the Cd for the EVO IX is 0.34 to 0.36.
I won't show the math, but since the Cd is linear in relation to the drag of the car, the car's overall drag at a given speed will be reduced by 1.1%.
Basically all things considered, the reduction in drag is negligible and at high speeds its like adding 4.4 lbs of downforce. Might seem like small gains but it's actually a nice little gain considering you aren't actually adding much to the car. I guess the real question becomes:
The extra downforce in the rear end will either decrease oversteer or increase understeer depending of what condition you currently have... is that what you are looking to do?
If you feel the car is oversteering, then I'd say go for it, if you think the car is understeering I'd recommend NOT doing it.
