coolant temp reads negative 77?
Old Apr 17, 2012 | 08:24 PM
420a-t's Avatar
What would cause this? i know on dsm's its because of the coolant temp sensor out, what about on evos???
any help is greatly appreciated. thank you
josh
Old Apr 17, 2012 | 09:33 PM
barneyb's Avatar
Do you mean like off the bottom of the gauge?
Old Apr 17, 2012 | 09:38 PM
420a-t's Avatar
No in my tuning software. Its always read correctly, however I cannot start my car now and keep it running. And I noticed my logs say -77F for coolant temps.
Any ideas? Would anything else cause this?
Old Apr 18, 2012 | 08:12 AM
GTijoejoe's Avatar
absolutely no modifications to the sensor or wiring?
Faulty sensor ?
Old Apr 18, 2012 | 08:21 AM
Pitside's Avatar
Faulty sensor. Sensor is grounded out. The ecu sends out a 5v reference. Then sensor is nothing more than a variable ohm. Unplug the sensor. One wire will read 5v the other should have a good ground. If that checks out then ohm the sensor. If its infinte ohms sensor is at fault.
Evo47
Jul 16, 2018 10:49 AM
asu11
Oct 9, 2016 05:43 AM
edsct9a
Dec 20, 2015 06:49 AM
stunt2
May 20, 2015 10:59 AM
KillaItalian904
Jan 9, 2013 01:40 PM
