problems!!!!! BATTERY/ E BRAKE LIGHT ON
Old Apr 26, 2012 | 09:12 PM
MaDD-Myke's Avatar
MAN IF IT AINT ONE THING ,ITS ANOTHER...WELL I HAVE A EVO 9 BOV ON MY EVO 8 AND I BOUGHT A SSQV BOV TO PUT ON THERE BUT I DECIDED TO PUT IT BACK ON LIKE 2 SECS LATER...AFTER THAT MY BATTERY LIGHT AND HAND BRAKE LIGHT CAME ON AT THE SAME TIME AND MY BATTERY WENT DEAD THERE AFTER.....TOOK THE BATTERY TO AUTOZONE AND THEY HAD IT CHARGING FOR LIKE 30 MINS BEFORE THEY TOLD ME IT WAS DEAD SO I BOUGHT A NEW ONE THINKIN THAT WOULD TAKE OFF THOSE LIGHTS BUT INSTALLED THE NEW BATTERY AND THE BATTERY AND HAND BRAKE LIGHT IS STILL ON...WHAT DO I DO NOW??????
Old Apr 26, 2012 | 09:24 PM
SunnyC's Avatar
you have a bad alternator.. check if its charging. should range 13-14 v.
brake light + batt light = normally bad alternator
Old Apr 26, 2012 | 09:28 PM
sujinX's Avatar
take off the CAPS LOCK.
definitely sounds like an alternator going bad or IS bad. when u were at autozone, you should have them check it.
ProPilot04's Avatar
The brake light and the battery light on means there's a charging system fault. It will have nothing to do with the BOV.
If your battery went dead for seemingly no reason, I would suspect your alternator. You should check the current and be sure that it's charging your battery properly. If your alternator is good, and your battery is good, then check the alternator fuse... it may have over volted.
You should also be able to find this out through:
1. Search.
2. Your owners manual.
I mention that not to be a dick, as I realize when sh*t hits the fan, sometimes people are on their phones or whatever, and that sometimes... used cars have no manuals...
I mention it so others might know where to find such things.
Let me know what you find.
Old Apr 26, 2012 | 09:44 PM
MaDD-Myke's Avatar
dont have a owners manual. you know the dealership charges an arm and leg for that ****
Old Apr 26, 2012 | 09:46 PM
MaDD-Myke's Avatar
dammit !!!!! must be the altenator then , how much to replace that
Old Apr 26, 2012 | 09:51 PM
ProPilot04's Avatar
Billions.
I'd check the voltages first so you don't go and replace a perfectly functioning alternator when all you need to do is check a fuse.
Old Apr 26, 2012 | 09:54 PM
SunnyC's Avatar
you do it at a shop they'll rape you.. better off doing it yourself. even found you a used one. but up to you if you want a brand new one.
https://www.evolutionm.net/forums/ev...lternator.html
http://evoscan.com/vehicle-manuals
https://www.evolutionm.net/forums/sa...lternator.html
Old Apr 26, 2012 | 10:03 PM
MaDD-Myke's Avatar
where do you find the altenator fuse?
Old Apr 26, 2012 | 10:22 PM
SunnyC's Avatar
you only have 2 fuse boxes.. engine compartment and below driver dash. i forget where the alternator fuse is. i highly doubt its a fuse.
Old Apr 27, 2012 | 08:10 AM
blowngasket's Avatar
i do have a Core OEM alternator i could have rebuilt for you if you like for a lot cheaper then a new or aftermarket one. This is my old alternator that was over charging i got a bad one and had it rebuilt so i would not have any down time. this job take about 2 hours to do by yourself.
Old Apr 27, 2012 | 08:29 AM
InoNothingMR's Avatar
WARNING.
It will probably take longer than 2 hours unless you have a method to lift the engine. Pulling that alternator through where the axle is (what I did) or through where the fuel rail is will be a pain in the a**. Some people on this forum find it very difficult (me), others say its only 2 hours just so you are aware.
Also, this is exactly what my car did when my alternator/battery went bad.
Old Apr 27, 2012 | 10:46 PM
Marcac's Avatar
Yes, please check the fuse before replacing the alternator. The fuse is the large 100amp fuse located directly on the positive battery terminal, it is not in a fuse box.
Old May 1, 2012 | 05:39 PM
clubEVO93's Avatar
Mine did the same thing. But I took mine out in about 4 hours. First time, the parts that got me were the 32mm axle nut was a ***** to get off, and the whole axle removel. But i didnt have to lift the engine. I just moved the alternator around and t slipped out behind the oil pan. With little space. But it turns out my alternator was fine. The wires that lead from the battery to the alternator had come lose and they were making a bad connection and werent charing. GL
Old Jul 13, 2012 | 03:14 AM
rhd-jon's Avatar
Fml im having the same problem with my 8 right now. Light fomes on and off sometimes it stays on. I will start by checking the fuse then ill ho ahead and have autozone check the altenator.
