problems!!!!! BATTERY/ E BRAKE LIGHT ON
Old Dec 28, 2012 | 05:26 PM
GBAILEY472's Avatar
So do we have a answer to this problem??? Op what did you do ?
Old Dec 29, 2012 | 07:46 AM
Shortbus115's Avatar
Based solely on the posts in this thread. If I had this issue pop up I would check my battery connections first because its the cheapest and easiest fix. Then I would test my battery to see of it was dead. Then I would test my alternator to see if it needed replaced.
That way you've gone from cheapest and easiest fixes to most expensive and difficult. Good luck
Old Jul 10, 2014 | 05:15 PM
angela77brooks1's Avatar
03 Lancer LS
Okay I have changed this alternator 3x and still my battery and brake light come on... Replaced the alternator with a mitsubishi one still the same problem it keeps telling me my voltage regulator is bad...
Old Jul 10, 2014 | 07:14 PM
brunz44's Avatar
Just my 2 cents do not buy a auto parts warehouse alt. Go oem made the mistake lasted a month. Also to change, pull passenger axle drop it from bottom, I spent more time getting pissed off wiggling it under intake mani, jacking motor, blah blah blah, then going the axle method
Verlassene
Dec 7, 2015 11:04 PM
Verlassene
Dec 3, 2015 09:46 PM
sik_z33
Oct 16, 2014 08:18 PM
prack7
Aug 8, 2014 09:13 AM
stuperstar19
Lancer Troubleshooting
18
Apr 20, 2011 03:07 PM
