Do Evos ecu store data?
Old May 1, 2012 | 05:42 PM
fastyouth1313's Avatar
Originally Posted by DrDeC
It does it while sitting out of gear though so wouldn't that mean boost had no part in it?
did you check your plugs?
Old May 1, 2012 | 05:43 PM
Old May 1, 2012 | 06:10 PM
DrDeC's Avatar
I will be working on it tomorrow so I can check tomorrow but there is no misfire or anything below 3k so could it still be plugs?
Old May 1, 2012 | 07:04 PM
yup! as soon as boost picked up it would feel like i was hitting the rev limiter. and it sometimes would do it at idle. it blew my gaps way out of tolerance.
Old May 3, 2012 | 12:40 PM
DrDeC's Avatar
I checked the gaps and they are fine only thing is could it be my maf?
Old May 3, 2012 | 02:36 PM
hhhhhmmm you can try swapping MAFs if you know someone local.... if it was your maf though i think it would throwing a code....
im gapped to .22 was yours somwhere near that?
Old May 3, 2012 | 04:44 PM
evo8426's Avatar
If the pipe is leaking it will still have trouble revving. I had it happen to me about a year ago and it was a boost leak just like you are describing.
How old are the plugs?
Old May 3, 2012 | 10:25 PM
DrDeC's Avatar
plugs have maybe 3k on em and it builds boost fine under 3k and when i let off i can hear it recirculate fine i think, ANYONE LOCAL TO THE MEDINA OHIO AREA? lol
Old May 8, 2012 | 08:15 PM
DrDeC's Avatar
I was told today it was my balance shaft bearings, here is a video, take a listen and tell me what u think!!!
http://www.youtube.com/watch?v=2i_9t...&feature=g-upl
Thanks!
Old May 10, 2012 | 08:10 AM
DrDeC's Avatar
bump for help!!
Old May 15, 2012 | 07:37 PM
DrDeC's Avatar
Not feeling the love fellas... BUMP
Old May 16, 2012 | 05:56 AM
Im thinking it may be a fuel issue man. Fuel cut out so after 4 rpm it makes that grinding all the way down to idle?
Old May 21, 2012 | 10:11 PM
DrDeC's Avatar
no it's not a grinding it's like a bogging noise?
Old May 22, 2012 | 08:54 AM
grim~'s Avatar
you're in ohio,id take it to buschur asap.
mrfred
Sep 14, 2022 07:08 PM
SsZERO
Mar 15, 2019 01:40 PM
ziad
Mar 2, 2016 02:26 AM
mrfred
Feb 21, 2011 06:01 PM
monsta
Jun 15, 2009 01:14 AM
