throttle response cutting out
Old Apr 30, 2012 | 11:23 AM
breeze17's Avatar
i was driving my car this weekend n my throttle reSponse kept cuttin out between 4-6k rpm. I recently installed test pipe. have new Wally 255 n ams regulators. any IDE? Im due for my 90k also just reached it
Old Apr 30, 2012 | 03:09 PM
breeze17's Avatar
bump
Old May 1, 2012 | 06:40 PM
breeze17's Avatar
anyone
Old May 1, 2012 | 07:20 PM
Thore's Avatar
Tune for those mods?
Change plugs?
Old May 1, 2012 | 11:43 PM
kamakazy_kid's Avatar
Cutting out as in it sounds like a double clutch? If this is the case then your Clutch is probably going. Just like mine did recently.
Old May 2, 2012 | 06:15 AM
breeze17's Avatar
i have not gotten a tune yet for these mods and I don't think it's my clutch because it was my gas peddle. whenever I WOT it would stop for about a second around 5k rpm and then catch back on and repeat.
Old May 2, 2012 | 06:20 AM
kaonashi's Avatar
Fuel cut mines doing same right now. Trim levels need to be raised it feels like its hitting a wall or stalling around 4k-6k in 4-5gears? Mine just hit 92k so it might be similar issue car still has the OEM clutch in it.
Old May 2, 2012 | 02:59 PM
slvrevosd's Avatar
Throttle position sensor?
Old May 3, 2012 | 07:38 AM
Initial_r90's Avatar
car I looked at last night had this same issue
Old May 3, 2012 | 09:00 AM
kaonashi's Avatar
I'm sure the TPS would throw a code Im only getting a code for EGR p0401
Old May 3, 2012 | 08:48 PM
breeze17's Avatar
Exactly 4-5 gear cuts out. could it be the fuel computer because my mechanic said somethin about that. also 2 weeks ago my car died while I was driving n it happened right after my fuel cut out at 5k rpm. turns out it was a blown fuse the engine sensor fuse I relieve the 8th spot on the engine bay fuse box. bought new fuses n went through a whole 6 pack in about 20 minutes. turns out something was wrong with my fuel system
Old May 3, 2012 | 10:02 PM
Anarchy99's Avatar
Fuel cut, the end.
Old May 5, 2012 | 09:12 AM
breeze17's Avatar
Thumbs down
Originally Posted by Anarchy99
Fuel cut, the end.
we know this.. how do you fix it?
another thing. yesterday when I was drivin my turbo went out. there is no spool up or whine down or anything. I can hear my intake suckin in air but that's about. I checked all my lines ICP and boost lines and everything was connected so wtf is goin on right now!!!!!
Old May 5, 2012 | 09:13 AM
breeze17's Avatar
I'm basically drivin a lancer right now /: and it sucks. no offense to ppl with lancers
Old May 5, 2012 | 10:49 AM
tkrizzy3's Avatar
Try making sure the gap on the plugs is exactly correct. I was having the same problem with an srt-4 i had for a little while. Would cut out in high rpms, got some new plugs and made sure the gap was spot on and it fixed it.
