Oil feed line help!!
Old May 2, 2012 | 12:51 PM
AllOutEvo9's Avatar
What size is the bango bolt that is pulled off of the block from the stock evo 9 turbo also where can i order one so i can run oil feed line thanks for your time guys.
im needing one of these
Old May 2, 2012 | 12:53 PM
okevolutionVIII's Avatar
Should be M8x1.25
Old May 2, 2012 | 12:55 PM
AllOutEvo9's Avatar
Originally Posted by okevolutionVIII
Should be M8x1.25
thank you ill check that out
Old May 2, 2012 | 12:58 PM
FlyingCaveman's Avatar
I don't know what size banjo that is, but have you considered getting the gen 2 oil feed from buscher? If not check it out... If you're running anything more aggressive then a stock turbo (I'm guessing yes cause of your huge tube manifold) they found oil pressure can drops dangerously low at the head. Good luck finding that fitting and sorry couldnt be any more help.
Old May 2, 2012 | 01:04 PM
AllOutEvo9's Avatar
thanks for the info
Old May 2, 2012 | 03:16 PM
slvrevosd's Avatar
Buscher for sure
Old May 2, 2012 | 03:23 PM
Team Foren's Avatar
Modern Automotive Performance has a nice kit that taps into the oil filter housing where there is plenty of oil pressure.
Old May 2, 2012 | 05:27 PM
todd6027's Avatar
Should be M8x1.25
m10x1.25
Old May 2, 2012 | 06:14 PM
markae86's Avatar
i second that.
evolve_VIII
Dec 7, 2015 05:51 AM
pandaevoz
Midwest Region
May 13, 2012 12:51 PM
satellite
For Sale - Wheels / Tires
15
Apr 28, 2011 01:49 AM
kelvar13
Jun 28, 2010 06:55 AM
blue_machine
12
Jan 10, 2010 09:16 PM
