Invidia Testpipe
Old May 3, 2012 | 07:08 PM
xbattousai's Avatar
Invidia Testpipe
I install a week ago, and start car no cel. Drove few miles cel came on, and it went away. Just came on again while driving to work should I be worried?
Old May 3, 2012 | 07:53 PM
thedru13's Avatar
Did you do an 02 extender?
Old May 3, 2012 | 08:04 PM
Runker's Avatar
check your o2 sensor
Old May 3, 2012 | 08:12 PM
xbattousai's Avatar
I didn't think I needed the extender, and I will take a look at it this weekend.
Old May 3, 2012 | 09:29 PM
johnnydemz4G63's Avatar
Or you can disable rear o2 with evoscan like my buddy did for me.
Old May 3, 2012 | 09:39 PM
sujinX's Avatar
seriously?
u put a test pipe in place of a cat and you didnt think you need to correct the rear o2?
the rear o2 is to check the effective efficiency of the cat. make sure its doing its job, you removed the cat. so of course the efficiency of the cat is zero, its not there so its not doing its job, thus cel.
u can do the mechanical fix ie o2 extender
or you can disable in ecu.
Old May 4, 2012 | 04:27 AM
xbattousai's Avatar
I thought the test pipe already had cel fix with it already.
Old May 4, 2012 | 05:45 AM
endlesss's Avatar
Even with extender, I've seen mixed results. Best bet like mentioned above is to access the ECU and defeat the code.
Old May 4, 2012 | 06:35 AM
romogst's Avatar
I"m using an extender with my test pipe , no cell going for 5 years now.
thedru13's Avatar
(knock on wood) I have not had a cel issue with the extender.
Old May 4, 2012 | 10:41 AM
xbattousai's Avatar
Thanks I will order the extender today.
Old May 4, 2012 | 11:04 AM
evo8426's Avatar
Why order one? You can pick one up at a car parts store like NAPA or Autozone and be done with the light today
Old May 4, 2012 | 11:14 AM
Evoluvin's Avatar
extender FTW.
Old May 4, 2012 | 11:25 AM
Mistaken's Avatar
I have the extender on mine and zero CEL.
Old May 4, 2012 | 12:21 PM
chin0's Avatar
^^^+1
