aftermarket FPR
Old May 16, 2012 | 05:35 PM
5LEEPERISAH23I's Avatar
aftermarket FPR
is it bad in idle to run your FPR at 32-35PSI? i no ur sopossed to run 43 or something but my a/f is so lean when i run that and it stalls itself out
Old May 16, 2012 | 08:37 PM
Joshthree6three's Avatar
? Its lean at 43psi and you want to run 3X?, that doesn't really make sense to me. I could see if you would want to run more fuel pressure than 43. But again that's not really the right way to do it.
I think you should have someone look at your fuel maps.
What is your afr at idle?
Old May 16, 2012 | 08:41 PM
The higher the fuel pressure you have the more fuel you can push through the injector when its open. Thats why fuel injectors are rated for higher flows at higher fuel pressures.
Or at least that is my very basic knowledge on that topic.
FlashEvolution
Jul 31, 2017 10:13 AM
Awd_evo
Apr 25, 2016 02:51 PM
Grip Master
32
Sep 18, 2015 01:09 PM
nwa7265
Jun 8, 2012 01:32 PM
EvODavO
13
Feb 28, 2009 04:09 PM
