rattling noise from under the car
Old May 25, 2012 | 08:50 PM
Travenport's Avatar
So, i'm getting a weird rattling noise that is definitely coming from underneath the car. It never rattles while the car is idle. It starts once i hit about 15-20 mph. Its killing me because I cant figure out what it is! I've put it on a lift and nothing seems to be visually loose. Ive physically checked all the big things that may have been causing it (exhaust, O2 sensor, various piping).
Sorry I dont have an audio file to share. Since it only occurs while the car is moving, the sound gets distorted by wind.
Does anyone have any other ideas as to what this could be?
Old May 25, 2012 | 08:53 PM
EVO KNVL's Avatar
cat shield? any rattle when just reving?
Old May 25, 2012 | 08:57 PM
detroit pistins's Avatar
couple of things come to mind;
1) aftermarket downpipe banging on the tie bars, especialy if they werent spaced down.
2) there is a small squarish looking plate around the drive shaft, check if its hitting anything.
gl!
Old May 25, 2012 | 09:03 PM
fastyouth1313's Avatar
+1^
That's what mine was
Old May 25, 2012 | 09:22 PM
lostsoulsevo's Avatar
gl!
+1
Old May 25, 2012 | 09:33 PM
GaBe511's Avatar
Mine was the factory downpipe heatsheilds coming loose. I just smacked them off with a hockey stick.
Old May 25, 2012 | 11:06 PM
Travenport's Avatar
No rattling when i rev, only happens once i gain some speed, but Ill take a look at those tomorrow and post results. Thanks for the input so far
Old May 26, 2012 | 07:17 AM
evo8426's Avatar
The downpipe can also be hitting the sway bar above the downpipe
Old May 27, 2012 | 09:24 PM
I think i might have to add this hockey stick tool to my toolbox.
Old May 28, 2012 | 06:24 PM
17579EVO9MR's Avatar
Mine is the heat shield above the drive shaft. It's annoying as heck
Old May 28, 2012 | 10:11 PM
Breakingakajav's Avatar
I'd put it back on a lift and knock on the heat sheilds first.
Old May 29, 2012 | 09:28 AM
HREEvo's Avatar
I have 4ich tubing and I know it was touching the heat shield, so I had to remove it. Even at idle it would make noise. As well as ur car's exhaust system slightly moves when the car is in motion. If its stock exhaust could be ur mounts need replacing.How many miles u have on the car? Like one of the members said try removing the heat shield first.
Old May 31, 2012 | 05:58 PM
Travenport's Avatar
78,000 miles on it. Ill check the heat shields on saturday when i can get to a lift. Thanks for the responses so far.
Old Jun 5, 2012 | 01:26 PM
Travenport's Avatar
I pinpointed the problem.
When i was doing my oil change to day i noticed a piece on the drive shaft that wasnt all the way secure. Not sure what it is but i pushed it all the way back to where it looked like it was supposed to go and voila.
Old Jun 7, 2012 | 10:41 PM
b00stin evo8's Avatar
Mine has the same problem with the damn downpipe heat shield...
I am way to lazy to get under there after doing the test pipe last month. The problem will get fixed after my BR pipe gets in
Braydo25
Lancer Troubleshooting
Aug 15, 2015 07:54 PM
dxlykos0131
Dec 8, 2013 07:59 PM
gkew
Aug 3, 2013 11:19 PM
vszutu
Toronto Lancer Club
Mar 15, 2013 05:09 AM
WADADLIG_OZ
14
Feb 20, 2004 03:57 AM
