ecu reset?
Old Jan 26, 2004 | 11:45 AM
mifesto's Avatar
ecu reset?
i just got an intake, exhaust and highflow cat installed this weekend... i was told to reset the ecu. can anyone give me a few more inputs?
Old Jan 26, 2004 | 11:47 AM
steve0677's Avatar
unplug ur battery for 15min or so
Old Jan 26, 2004 | 12:10 PM
mifesto's Avatar
someone said only couple minutes is enough... so i guess i should reset ecu whenever i add boltons
Old Jan 26, 2004 | 12:50 PM
Yellow8's Avatar
Yes, any time you add a performance intake or exhaust part you should reset the ECU. The computer will then reset so that your ecu will not read the different performance of the car as wrong, and throw you a service engine soon light. That is what I was told anyway.
Old Jan 26, 2004 | 12:51 PM
boomn29's Avatar
Think of it as a 'Learning' Computer Unit
Old Jan 26, 2004 | 01:37 PM
mifesto's Avatar
thanks
Old Jan 26, 2004 | 05:27 PM
Michael A's Avatar
How about pulling the ECU fuse in the engine bay ?
Someone told me this would work also.
You think I should reset my ecu being that I just installed my Burchur muffler delete pipe ?
Old Jan 26, 2004 | 05:35 PM
the evo wins's Avatar
just unplug the damn battery it only takes like 30 seconds
Old Jan 26, 2004 | 05:36 PM
Michael A's Avatar
Doesnt this lock my radio and require me to enter the radio code ?
Old Jan 26, 2004 | 05:56 PM
all it does is reset the "mileage count" thing to 0 (not the overall mileage of course) and reset the radio preset stations and bass/treble settings along with the clock
Old Jan 26, 2004 | 07:31 PM
evo542's Avatar
you can never reset the mileage no matter how many times you unplug the battery
Old Jan 26, 2004 | 08:16 PM
yeah no **** shirlock...i was talking about the trip A and B thing
Old Jan 26, 2004 | 08:24 PM
Creamo3's Avatar
I hear depressing the brake pedal with the battery unplugged purges any leftover electrons left in the system. Usually just unplug the battery whenever you add something to your car and when your done the ecu is clear.
Old Jan 26, 2004 | 08:32 PM
Ryanmcd3's Avatar
In Timeout
Do this, unplug the neg batt cable and hold the brake pedal down for 12 seconds, if done correctly your clock will goto 1:00, your cd will eject as well as your radio stations will reset. If the cd and clock are NOT re-set do it again. Just hold the pedal down for 15 seconds to be sure. I have done this over 5 times and know it all to well
Old Jan 26, 2004 | 08:44 PM
nebolic's Avatar
or heres another trick, put your key in the ignition and turn it on 3-5 times really fast, to the on postion but not starting the car, that resets the ECU too.
