Stock block setup Safe?
Old Jun 5, 2012 | 09:20 AM
lopillo_evo's Avatar
Veteran: Army
Okay so I'm almost done with buying stuff for my car. Head going to the shop next week. This is on stock block and 91 oct. I want to thanks MAPerformance Chris Awesome guy to work with and Amazing Costumer Service!!!!!!!!!!!!
03 Evo 8
Mods
GSC S2
Supertech Dual Valve Springs
3" TBE
Megan o2- Switching to Map o2
Walbro 255
PTE 1200cc
ETS FMIC with Piping
ACT HDSS
EF3
What hp/tq you guys think it will be safe? Block is going to get done probably next year since budget is getting low,I have other priorities (family). Thanks in advance.
Old Jun 5, 2012 | 09:26 AM
evoforstevo's Avatar
I would say around 450 tq on e85. Since you were on 91 might say a bit less just because of the more likely presence of knock. I would also consult MAP. they've tuned enough evos to where they'll have a good answer for you. Great choice of tuner and Turbo! Best of luck.
Steve
Old Jun 5, 2012 | 09:38 AM
^^^EVO 8
Im guessing you will see approx 340-360HP & TQ on a DynoJet at 25PSI
What do I know, Just an guesstimate based on the mod list
Old Jun 5, 2012 | 09:41 AM
Veteran: Army
Thanks for the input guys I will contact Chris!
Old Jun 5, 2012 | 10:01 AM
pacent's Avatar
I suggest head studs if you're going to lift the head. Might as well get it done while you're there.
Old Jun 5, 2012 | 10:22 AM
Veteran: Army
Yeah I forgot to list those as well
Old Jun 5, 2012 | 02:22 PM
djdnav's Avatar
The mods you have aren't a threat to the block really untill you swap to a larger turbo. Just find a solid tuner and as long as you're not knocking you should be fine.
I have a similar setup to yours:
Kelford 264's
3" TBE
Stock o2
Walbro 255
PTE 1200cc
ETS FMIC
9 turbo
arp studs
93 oct/30psi
Made 370 dynojet
Old Jun 5, 2012 | 04:00 PM
jvlazzar's Avatar
Kelford 264's
3" TBE
Stock o2
Walbro 255
PTE 1200cc
ETS FMIC
9 turbo
arp studs
93 oct/30psi
Made 370 dynojet
you missed the EF3 turbo. either way, with a safe tune that's mindful of torque, you'll be fine.
Old Jun 5, 2012 | 07:06 PM
Frew's Avatar
he was talking about his tune, not the OP. What would be the difference between evo 8 vs 9 with same mods?
Old Jun 5, 2012 | 08:51 PM
Veteran: Army
thanks guys for your opinions!!!
Old Jun 5, 2012 | 09:32 PM
awdordie's Avatar
Frew... apparently not much. i came close to making what djdnav made on an 8 turbo.
my setup is
arp studs, cometic hg, hks 272's, hks suction pipe, ic and piping, 3" tbe with test pipe, evo 8 turbo with 10.5 hotside, forge wga. car put down 356/364 i think it was on the eculfash vd. car was tuned by Chris @ Mellon Racing on 26psi
there are plenty of people making 400's on the 9 turbo though.
Old Jun 6, 2012 | 04:25 AM
Mellon Racing's Avatar
we usually stop pushing for more tq ~ 400 on the stock rods. We have a few guys at 460tq but they were prepared to buy a new shortblock already and just wanted to see what their setup was capable of. As far as I know they are still running fine today but I still don't feel comfortable at that level.
Old Jun 6, 2012 | 05:39 AM
PatricksEvilEvo's Avatar
I recommend good motor mounts all around. I'm at 360tq/hp and shifting can be harsh if not careful.
I'm on 9 turbo, stock 9 motor, 3"tbe, mbc, drop in filter, IC+pipes and 255 pump peak 27psi. I don't know why I have such high numbers, I guess every car is different but those numbers are on a Mustang dyno. I definitely expect you to have more than me with that list.
Old Jun 6, 2012 | 07:41 AM
Veteran: Army
those are really good numbers man!
Old Jun 6, 2012 | 08:01 AM
OstarMotorsport's Avatar
You should be fine on that setup with the stock block. We have a daily driver Evo 9 MR on a very similar setup except using an fp black. The only issue I see is running 91 oct. We generally use e85 but on pump you will have to be more conservative on the tune. If MAP is going to tune it then your in good hands.
