Horn doesn't work
Old Jun 18, 2012 | 10:43 AM
yacubkep's Avatar
Veteran: Air Force
Horn doesn't work
Key fob makes the horn go off, but actually hitting the horn on the steering wheel and nothing...
I have checked all the fuses I could think of and have had the steering wheel all apart to replace the whole assembly and still nothing...
Any one on here have any other ideas?
Old Jun 18, 2012 | 11:45 AM
Revo15's Avatar
Check the wiring properly..may have high resistance or an open circuit maybe the switch in the steering wheel is defective.
Old Jun 18, 2012 | 11:46 AM
Revo15's Avatar
But before u do that test the fusable link.
Old Jun 18, 2012 | 12:19 PM
yacubkep's Avatar
Veteran: Air Force
fusable link?
Old Jun 18, 2012 | 12:30 PM
yacubkep's Avatar
Veteran: Air Force
isn't there 2 horns on the evo??? does one work with the fob and the other the horn?
Old Jun 19, 2012 | 08:16 AM
1japdsm's Avatar
I had the same problem. Mine was the wiring behind the steering wheel came loose.
Old Jun 19, 2012 | 12:52 PM
yacubkep's Avatar
Veteran: Air Force
behind the steering wheel or the actual button part?
Old Jun 19, 2012 | 06:22 PM
Frew's Avatar
is the relay clicking when you push the horn? My horns died and someone ghetto rigged them with like literally 3 other horns before I bought the car, people are idiots....
Old Jun 19, 2012 | 07:07 PM
dapursel's Avatar
check fuse, if good, check to see if you have pwer at relay when pressing horn button, if not it could be the clock spring behind the steering wheel.
Old Jun 19, 2012 | 07:08 PM
dapursel's Avatar
you can also check to see if you have power at the horn itself when pressing horn button 1st, it could be a bad horn.
Old Jun 20, 2012 | 03:14 PM
yacubkep's Avatar
Veteran: Air Force
great ideas!!, the next time I have help I'll have to give them a try... maybe tomorrow if the flooding stops up here.
Old Jun 20, 2012 | 08:46 PM
ramahskagromik's Avatar
+1 darpursel
Old Jun 22, 2012 | 11:49 AM
yacubkep's Avatar
Veteran: Air Force
well I was doing a bit more digging about clock springs and think that may be my problem....
SRS light is on, horn doesn't work, blinkers don't stop if wheel is turned, brights don't stay on if clicked.
Old Jun 23, 2012 | 02:55 PM
yacubkep's Avatar
Veteran: Air Force
anyone know where I can order a new Clock spring? I have no dealers in a 150 mile radius.
lghtngyello03
May 1, 2020 01:15 AM
inslowoutfast
Apr 21, 2017 06:19 AM
Ernest Latcher
Jan 4, 2017 06:31 AM
j0hne
Lancer Troubleshooting
Apr 28, 2016 02:19 PM
