Mbc vs wastegate forge
Old Jul 9, 2012 | 08:01 AM
steven121's Avatar
Quick question
I had a forge wastegate on my old lancer and I loved it
But since I have an Evo is it more beneficial to use an mbc and how much boost would that get me to? I know how to tune just learning new stuff
And I have an Evo 9 turbo as well
Trying to search but I'm at work
Old Jul 9, 2012 | 04:26 PM
djdnav's Avatar
I have a hallman pro, and i got 33 psi out of a 9 turbo with cams/injectors/bolt ons. However, the boost level you are able to make and maintain depends on your setup.
Old Jul 9, 2012 | 05:54 PM
steven121's Avatar
So I should just go with an mbc instead of forge so I can make the more, or will the forge hold the boost better?
Old Jul 9, 2012 | 06:27 PM
Raptord's Avatar
An mbc doesn't replace your wastegate.
Old Jul 9, 2012 | 06:32 PM
Frew's Avatar
Wouldnt a 25 psi wastegate let you hold more boost closer to redline?
Old Jul 9, 2012 | 06:48 PM
Raptord's Avatar
Yes, but without some form of boost control you'd be pretty much stuck boosting 25 psi at all times, across the whole rpm range.
Old Jul 9, 2012 | 07:00 PM
wizzo 8's Avatar
Yes you need both a wastegate and some sort of boost controller. If you are only boosting 10psi or less then maybe a wastegate on its own will work but you need a boost controller also.
Old Jul 10, 2012 | 04:43 AM
Frew's Avatar
I have read up on it a bit, apparently if you were to go with a 25 psi actuator you will creep in boost at higher Rpms, dependent on your set up. From my research the best combo to control boost and bleed would be an 18 psi actuator with it preloaded and a gm or grim speed three port.
Old Jul 10, 2012 | 09:49 AM
steven121's Avatar
So pretty much the stock wastegate followed by a grim speed 3 port
Old Jul 10, 2012 | 10:01 AM
Raptord's Avatar
Everyone has their preferences as far as MBC vs EBC vs 3-port, but the grimmspeed 3-port is what I use for my car and I love it.
Old Jul 10, 2012 | 11:54 AM
steven121's Avatar
sounds good thanks a ton, i decided not to get the forge wastegate then I might as well just buy an mbc and use the other money for something else.
Old Jul 10, 2012 | 12:28 PM
jvlazzar's Avatar
ebc gives you gear-dependent boost control with the factory ECU, and i much prefer the "set it and forget it" mentality.
Old Jul 10, 2012 | 02:45 PM
Frew's Avatar
How hard is tuning using a 3 port?
Old Jul 10, 2012 | 02:48 PM
Raptord's Avatar
Originally Posted by jvlazzar
a 3-port gives you gear-dependent boost control with the factory ECU, and i much prefer the "set it and forget it" mentality.
Fixed. EBC and 3-port BCS aren't the same thing.
Gear-dependant boost also isn't the only advantage of using a 3-port.
Old Aug 28, 2012 | 11:46 AM
2OO3SILVEREVO's Avatar
use a hallman mbc with your set up i have used multiple times
