Xflash driving impression and theory of other flashes
Originally posted by rodw
Let me get this straight......
Shiv is now using Techtom for his xflashes....wasn't he the one telling everyone that Techtom sucks?
https://www.evolutionm.net/forums/sh...m&pagenumber=2
I'm not trying to start a flame war or anything but I was just wondering why the sudden 180??
Eric
shiv, thx for the explanation.
damn now i wonder if my autometer mechanical boost is reading correctly at high boost cuz mine is cheaper than nebolic's...LOL...
i know...i know...let's get back to the topic.
nah i dont think the boost gauge is that bad (autometer) i mean i just want a general reading, not looking for specifics, if i wanted specifics i'd buy a more expensive unit, but as far as functionality goes, it does the job for a non techie. ytsejam, i think we are good to go, no probs.
hahah we'll talk more $hit at tap x on saturday.
Re: Re: Re: Xflash driving impression and theory of other flashes
Originally posted by shiv@vishnu
Sean-- The dyno chart hasn't gone anywhere. It's still there, just scroll downwards a bit to see boost and AFR.
Remember that the charts (and all the XFlash charts posted on the forum) show the results on a stock car. Nebolic's car is not stock. It has a cat-back which raises boost approx 1psi.
My 2c,
shiv
My 2c,
shiv
Okay. Thanks Shiv.
Sean
I for one would like to see dyno results from the xflash on a stock car on a regular dyno (like dynapack). as good as shiv's may be i'd like some normalized numbers to compare it to the dynoflash and P2.
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Thwack, There is no such thing as "Normalized Numbers". Most of the dynos all differ in at least a little. The best comparison is to put both cars on the same dyno under the same conditions (temp, humidity, bar. pressure...). Only then can you get apples to apples comparison.
That is why I think that most attempts to quantify differences on these boards is fruitless. You can't really compare different dynoes, and 1/4 mile times are very dependant on driver ability.
I like the idea of test driving the different tuned cars, but this isn't very easy either.
Just an opinion from a non-tech.
well i have a news for u guys,
not to start a flame, but it's a kill story.
nebolic smoked an STi with MBC & Turboback earlier today by 1 car... xflash in action !
i didn't see it just heard the story
yeah, but most other dynos read pretty similar, whereas shivs tends to measure like 40 hp less than the rest. going off differencs in power from stock to flashed it seems that xflash raises like 20-25, as does p2, and dynoflash from 25 to 30... but is 20 hp increase on shivs dyno equal to 25 on any other dyno??
Now that that is out of the way, the Techntom "system" consists of some cables and DOS-based map editing software called Mighty Map. We use the software since it's already available and perfectly adequate for the job. But we made our own cables out of ECU connectors we had lying around
Like any other programming software language, simply having the program doesn't make you fluent in it. Although Techtom does get users up and running to a quick start by telling them where, in the ECU's hex code, to find the fuel, timing, boost taper, rev and boost limits tables. Of course, there are a few dozen other maps which aren't provided/translated and require actual digging/work to find. Once found, then one has to figure out (through what can only be called trial and error) what they represent and how they function. This is what took the extra time. And this is why the XFlash performs as it does.
Regards,
shiv
Vending, or alluding to the fact that you vend, is not allowed unless you have a Vendor account.
edit - Please note - I can't sell you anything - and you can't buy anything from me - I AM NOT SELLING ANYTHING
This information herinafter posted is technical data for the benefit of fellow evo m users - posted here by evo m members
https://www.evolutionm.net/forums/sh...383#post717383
https://www.evolutionm.net/forums/sh...4&pagenumber=1
- Note - i am not insulting anyone - I am not trying to sell anything - I am just posting facts and responding to comments made my other members about me - why is it that they keep giving me a hard time ???? Does anyone have any speculation on what is really going on here?
Other than the fact that California's premium unleaded fuel is garbage, I truly envy you left coast folks. To be able to walk into Vishnu tuning and get Shiv to tune your car.. That'd be pretty cool.
As far as flashes go, I'm not going to focus on anything but the Xflash, so as not to create anymore thread drama.
I do want to tell you guys why I'm choosing an Xflash to replace my SAFC with, though.
1) Area under the curve. Someone mentioned that the Xflash tapers a lot (from 23psi to 18psi) to redline, whereas other flashes taper a psi or none. As stated, Shiv wants it to be that way. While it probably isn't safe to hold 23psi to redline at all, he's having it rise up there for a much stronger torque bump, then settle to very safe levels. Think of how useful that will be on a roadcourse or autox.. Or if you don;t do those things, think about if you get next to another car on the interstate. When you mash the pedal in and wick up to a safely tuned 23psi, I promise you're going to be pulling harder than if you were at 19psi. It doesn't take rocket science to make the turbo hold a set level of psi (19), any one of us can do it with a $40 Hallman manual boost controller. The Xflash is set to taper because that's how it gets the best power everywhere safely, and gets great area under the curve.
2) Shiv off the shelf tunes are "torture tested" (quote from the Vishnu site) for extreme conditions. This is for repeated pounding on the car that occurs in conditions like road racing. Drag racing is nowhere near as hard on the motor and turbo.. You run through the first four gears for 12 seconds, then its over. I like the fact that the guy who wrote my ECU map is looking out for me on my track time when I'm relentlessly pounding the car again and again accelerating and braking and accelerating again for a full session.
3) I can upgrade to an XEDEflash later. This part takes the cake and runs away from the party in my mind. I get all free updates I can add myself without pulling the ECU to send off to be reflashed again, and if I get some of my own parts, I can take the car to any AWD dyno with a wideband O2 and make adjustments myself. I have the full ability to use the maps that Shiv works hard on, but I can also forage off for other mods myself. That's freedom as well as support! The best part is I can start with the Xflash and decide if I want to do this later.
To me right now, there is no other choice for ECU upgrades because none is nearly as complete, vast, or controllable by the end user, which is you- the car's owner!
