Driver side tail light out!
Old Jul 10, 2012 | 05:36 PM
jaymac87's Avatar
Question Driver side tail light out!
If anybody could help me with this I would be very very grateful
ISSUE:
Driver side tail light is out as is the license plate lights as well (same circuit). Brake lights work fine though.
What I've done:
I checked all the fuses under hood and under dash and all fuses are good. I switched the light housing (left to right visa versa) and the left side worked on the right for the tail lights so the housing is good as well. Whats weird is I pulled all the fuses out under the dash and put them back in and the tail light worked fine again for about a week and then out of no where stopped working again. Tried that trick again but no luck. Please HELP !!!!
Old Jul 11, 2012 | 12:48 AM
svt_lightning01's Avatar
If they are working then not working for no reason you have a wiring issue probably a loose ground.
Old Jul 11, 2012 | 02:10 AM
impact blue's Avatar
Check your grounds if that doesnt work it will be an obvious electrical issue. It's probably not major I would take it to a professional car electrician.
Old Jul 11, 2012 | 05:01 AM
akeric's Avatar
loose ground, possibly corrosion. Check the connector for any nicks in the wiring. Does your trunk leak?
Old Jul 11, 2012 | 07:14 AM
jaymac87's Avatar
I dont think my trunk leaks. Where should I look for the ground(s) to see if they are loose? Im guessing I should check the license plate lights for loose ground as well since it is in the same circuit?
Old Jul 11, 2012 | 09:46 AM
bhmax's Avatar
There's a wiring harness that plugs into the fuse panel under the dash. Remove/reinsert it and see if that changes anything. Installed a cruise control recently and left that harness unplugged and similar things happened.
Old Jul 11, 2012 | 06:09 PM
jaymac87's Avatar
I will give that a try @bhmax...anybody know where to check for loose grounds or possible corrosion (specifics) and again thank you for all of your replies so far!
Old Jul 11, 2012 | 06:43 PM
batty200's Avatar
The whole chassis harness is known to sometimes get corroded at the firewall and cause a ton of electrical issues. The easiest way to see if there is a ground issue is measure the resistance to ground from the harness and if it is above 1ohm there is an issue.
Old Jul 11, 2012 | 06:51 PM
Revo15's Avatar
Sounds like you got High Resistance in your circuit..use a Dvom and check for High resistance and also check see if your getting enough voltage.
Old Jul 12, 2012 | 10:46 AM
fit4130bmx's Avatar
do your rear bumper lights work on both sides?
Old Jul 15, 2012 | 07:14 AM
jaymac87's Avatar
What exactly do you mean by rear bumper lights? Ive also noticed when I use the turn signal for the left side the blinker on the dash flashes really fast but none of the light bulbs are bad???
Old Jul 15, 2012 | 07:22 AM
bhmax's Avatar
The same fast flashing happened when I left that harness unplugged.
Old Jul 15, 2012 | 09:07 PM
warstang27's Avatar
+1 03s are really prone to it. do a quick search and youll find a LOT of people have/had this problem
Old Jul 17, 2012 | 11:24 AM
jaymac87's Avatar
Unplugged both harness that go into the underdash fuse box (white, gray) and plugged it back in. No luck
If I am getting high resistance, how do I fix it? Install another ground and what about getting more power to it if that is an issue?
Old Jul 17, 2012 | 11:25 AM
jaymac87's Avatar
Anybody know which fuse controls these lights (under dash or under hood)? I am guessing under dash since removing those fuses and replacing them fixed it last time for about a week.
