Hot weather owners, how's the AC
My ac blows cold, but I only use it on the highway. If I use it on the street my car will stall when I come to stops or even slow down. Have had this problem over 2 years and have no fix in site.
When my car had A/C it blew pretty cold. I couldn't complain at all on the highway. But the A/C would, more often then I care to experience, make my car stall. Often when coming to a stop the A/C would bog the engine down.
I suspect it is not an issue unless the car is heavily modified. My car has never stalled because of AC. On a hot day stuck in traffic it is less than I would want but it does the job when you are moving. It also doesn't help that the aluminum shift knob gets so hot I cannot touch it. Nothing beats the AC in my trailblazer.
The only time my AC Stalls the Talon was when the ISC was bad. Of course, its got a very mild bolt-on cam. The only upgrade in the valve-train was an entire IX used valve train. It doesn't lope, the cams are degreed. Even if you go with a set of mild cams, as long as you degree them, and get a good idle tune your gonna be fine.
On a personal note, I love how this is now an "AC issue." Issue. As if the car was sold with an inability to run its accessories. Times like this is when I wish for pics to be attached to usernames.
I'm also in the the south florida area. i dont tend to use the car too often, but i did take her out and drove her to work last week, the weather has been regularly in the High 90s
the A/C worked perfectly for a 7 year old car.
