Fuel injector o-ring.. is this correct?
Old Jul 27, 2012 | 03:27 PM
EvODavO's Avatar
I recently replaced the orings on my fuel injectors because they were leaking. The new orings are also leaking slightly and i am not sure why. I could not get the oring to stay on the fuel injector, so i seated the orings into the intake manifold. Then I bolted down the fuel rail with the injectors into the orings. Is this correct. Or should the oring be able to fit around the lip on the fuel injector. here is a pic of how it currently sits, leaking slightly. also i did coat the orings in oil before i installed them.
Uploaded with ImageShack.us
Old Jul 28, 2012 | 07:30 AM
EvODavO's Avatar
bump
Old Jul 28, 2012 | 08:08 AM
CurseDSM's Avatar
Did you tq down the fuel rail to proper spec? Do you have the correct o rings for the injectors you have? Those are the questions your gonna have to ask being it sounds like one of those is prob the problem. If you need the proper tq lmk I can get it for you.
Old Jul 28, 2012 | 08:37 AM
420a-t's Avatar
Also mine have leaked in the past , but a simple little turn of the injectors one way or the other and they "seated" completely after that. tested up to 35psi no leaks.
Old Jul 29, 2012 | 04:46 PM
EvODavO's Avatar
they are the correct orings an they are torqued down to spec. ill try giving them a turn and see if they seal up. I was just wondering if the orings are supposed to fit around that lip on the fuel injector because i could not get it to.. that is why i put the orings in the manifold and bolted the rail with injectors down into the orings.. is that the correct way?
Old Jul 30, 2012 | 07:50 PM
EvODavO's Avatar
bump
TommiM
Jun 21, 2014 02:10 PM
sleepyghost
Sep 15, 2013 02:18 PM
evopowned
Feb 7, 2011 07:22 AM
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
16
Nov 5, 2010 03:44 PM
hawaiian_evo
Sep 8, 2009 08:36 AM
