AC compressor not kicking on/ wire cut
Old Jul 30, 2012 | 08:05 PM
Cadmonkey's Avatar
so iv been trying to figure out why my AC doesnt work. i finaly realized my ac compressor wasnt kicking in. so, i started looking around the compressor area and found the signal wire from the engine harness to the compressor was not only disconnected, but the black plug was missing.
this thread is almost exactly what happened to me. red wire w/ white stripe, and black wire w/ yellow stripe are just hanging out.
https://www.evolutionm.net/forums/ev...s-go-pics.html
so i get that the red wire goes to the power steering pump pressure switch, and the black/yellow wire goes to the ac compressor. but, my question is.. i put a volt meter to the black/yellow wire without the ac button on the hvac control panel disengaged and it read 0.00v. THEN i also tested it with the AC button engaged, also 0.00v. so, if i connect that black/yellow wire to the compressor, how will it engage the ac compressor with no volts when the ac button is engaged?
just a side note. i checked the ac relay in the engine bay fuse box and the arrow on the relay was facing the wrong way (to the right) so i switched it back to the proper direction (to the left) and tested the wire again. still 0.00v
Jetech38
Jun 16, 2015 03:26 PM
roblaza
Mar 19, 2012 10:25 AM
ApexSilver06MR
14
Dec 21, 2009 08:44 AM
benji
Nov 22, 2004 08:33 PM
Trustz
Apr 5, 2004 11:05 PM
