Letting EVO sit with gas in tank
Old Aug 22, 2012 | 04:10 PM
ev0mATT's Avatar
I'll be leaving soon for a few months and was wondering if it's okay to let the evo sit with gas in the tank. It's going to be a little over half a tank
Old Aug 22, 2012 | 04:30 PM
The Juice's Avatar
You can always just put some fuel stabilizer in it if your worried.
Old Aug 22, 2012 | 04:34 PM
TurboTal's Avatar
+1 for fuel stabilizer , most gas starts to change chemically after a month. If your not sure a little stabilizer will never hurt.
Old Aug 22, 2012 | 05:04 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
1oz. of STA-BIL Fuel Stabilizer for every 2½ gal. of gasoline, lasts about 12 months.
Old Aug 22, 2012 | 05:39 PM
donmeca2020's Avatar
well you can do either that, or have someone you trust go ahead and start the car up once a week and take it out for a spin.
I don't always drive my evo anymore, but i at least once a week pop the garage open and start it up for abit.
Old Sep 8, 2012 | 10:45 AM
ChicagoEvo9's Avatar
depends how long your leaving it, anything over 3 months isnt good but totally depends on your luck lol
Old Sep 8, 2012 | 10:50 AM
Tpatterson's Avatar
When I had my last car, over winter, I would let the car sit for 5 solid months over winter, with a full tank of 93 in it, and 5 oz of stabilizer in the tank, and it always fired right up after winter was over. When you add it to the tank, be sure to drive it around for a few miles to get the stabilizer through the whole fuel system. Also remove the battery and take it inside and put it on a battery tender so it doesn't die.
Old Sep 8, 2012 | 11:25 AM
bonsuz01's Avatar
I have a 1/4 of a tank on mine and I wasn't sure if its good, so I ended up draining it and use it on my lawn mower.
Old Sep 8, 2012 | 11:28 AM
SaulHudson's Avatar
Originally Posted by bonsuz01
I have a 1/4 of a thank on mine and I wasn't sure if its good, so I ended up draining it and use it on my lawn mower.
Lawn mower on premium? How did it run?
Old Sep 8, 2012 | 11:29 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
That's a really good point.
Old Sep 14, 2012 | 06:29 PM
forcedkseries's Avatar
I don't daily mine just turn it on once a week runs like a champ still
Old Sep 17, 2012 | 08:28 AM
reboundicon's Avatar
I've read it's better to leave a full tank of gas with fuel stabilizer and other people have told me it's better to leave around 1/4 a tank or less without stabilizer and it should be fine.
For guys that have stored their car in the past how much gas are you leaving in your car? Also how often are you starting your car while it is in storage (if you didn't pull the battery)?
Old Sep 17, 2012 | 08:48 AM
sourtowel's Avatar
Being from a cold climate that makes total sense. Freezing conditions cause condensation inside the gas tank, therefore creating water in the gas. If you are storing your car in a cold climate, without a doubt fill the gas tank and put the stabil in it.
Old Sep 17, 2012 | 09:14 AM
sujinX's Avatar
http://www.wikihow.com/Store-a-Car
everyone does it differently, it also depends on how long. but the only consistent thing is the stabilizer.
Old Sep 18, 2012 | 05:51 AM
boostedmkiii's Avatar
Haha, I always use v-power in my small engines... It's certainly worth it, considering the little amount I have to use.
Back on topic, I prefer using seafoam instead of stabil. I had stabil gum/gel up once in a different vehicle (correct mixture and everything) - Michigan winter. I always make sure to drive the car around for a couple days, staying out of boost, until I fill back up... I have had great success with seafoam.
