Evo Randomly dies.....tried almost everything. help
well bad news! Took the car out for a spin today and cutt off on me 3 times within a 3 mile radius!! When it cuts off and try to start back it will tumble and then die (car wont start). I have to switch off the turbo timer from counting down pull out the key and put back in the key and then it will start. i am totally stumped and fedup at this problem.!
someone else mentioned fuel pump relay-- start there and then I would look at removing first your turbo timer--not needed and could be the issue and then the kill switches you mentioned and finally the alarm. One at a time until you find the problem. electrical issues are the pits--
I tried doing what you suggest with the IACV and it only moves like a hair, you can barely even see that it moves. How much is the shaft supposed to move? 1/8", 1/4"? Mine probably moved 1/32" of an inch you could barely tell.
